Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
  • Getting Started
  • User Guides
  • Developer Guides
Table of Content
  • 20
Audio Object Developer Guide
  1. Purpose of this Document
  2. Overview
    1. Audio Object Workflow
    2. Audio Object Class
  3. Audio Object Configuration
    1. Design Time Configuration
      1. Metadata
    2. Advanced Design Time Configuration
      1. Audio Object Memory
  4. Basic Features and APIs
  5. Advanced Features and APIs
    1. Switch Processing State
    2. Debug and Monitoring
    3. Background Method
  6. Audio object Example Object
    1. AO Example - AwxAudioObjExt.cpp
    2. AO Example - AwxAudioObjExtToolbox.cpp
    3. AO Example - AwxAudioObjExtMemRecs.cpp
    4. AO Example - AwxAudioObjExt.h
    5. AO Example - AwxAudioObjExtToolbox.h
    6. AO Example - AwxAudioObjExtMemRecs.h
  7. General Guidelines
  8. Adding External AO into AudioworX Package
  9. Building External Audio Object
Starter Kit Developer Guide
  1. Overview
  2. Assembling and Configuring Starter Kit Components
  3. Setting Up the Developer Environment
  4. SKUtility Developer Options
  5. Build AWX External Object
  6. Running Debug Session
xAF Integration User Guide
Troubleshooting
  1. GTT Installation
  2. GTT GUI Issues
  3. AmpSRV2
      5.Advanced Features and APIs
      • Audio Object Developer Guide
      • Advanced Features and APIs
      These methods are optional and are usually used for more advanced algorithms that have a large memory footprint or require advanced features like live streaking.
      This code will be compiled for embedded libraries and used at runtime.
      • Audio Object Additional Configuration
      • Audio Object Sub Blocks
      This is the first method called by the framework to the object after its properties are setup according to the signal flow configuration. This method allows the object the opportunity to setup its configuration. The framework retrieves the additional configuration data the object is expecting from the signal flow file and sets these two audio object variables:
      • m_AdditionalSFDConfig – this is a void pointer that holds the additional configuration data
      • m_SizeofAdditionalVars – this variable will contain the size (in bytes) of the additional data
      The object is then responsible for configuring its internal states based on this data provided. The API to implement is:
      void assignAdditionalConfig()
      An example is provided below for the delay audio object.
      In the toolbox configuration, the delay object specifies it has the following 2 additional configuration variables:
      typedef struct AdditionalConfigs
      xFloat32 crossFadingDuration;   ///< first additional config param == Crossfading duration
      xUInt8 cntrlInputEnable;        ///< second additional config param == Control input mode (disabled, oneSet, multiset)
      So, accordingly, this is the data it expects as the output from the tool once the signal flow is designed.
      The endianness of this additional configuration data is passed to the object in little endian format.
      The Sub-blocks represents logical divisions of a block’s (or audio object’s) memory. They are partitions of the audio object’s memory.
      There are many reasons to use sub-blocks in an object.
      • Tuning data preservation is facilitated by the use of sub-blocks.
      • The data can be organized into more logical chunks.
      • The data will also be easier to debug.
      • In some cases, tuning preset files can store much less data. This is due to the fact that sub-blocks of the memory can be individually stored in the preset files as opposed to the entire object’s memory.
      Sub-blocks belonging to the same object do not necessarily need to have the same sub-block size.
      The two API calls associated with setting up sub-blocks in an object are:
      xInt8* getSubBlockPtr(xUInt16 subBlock)
      xSInt32 getSubBlockSize(xUInt16 subBlock)
      • getSubBlockPtr() is called by the framework to retrieve pointer to start of the subblock.
      • getSubBlockSize() is called by framework to get size of the subblock in bytes
      Here we will create an example of a simple object.  This object has one parameter (m_Gain).  It’s a float so its size is four bytes.  Since it is our only parameter we will only have one subblock it’s subblock will be zero (we start at zero).
      In this code we only return a valid pointer if our subblock is as expected.  If subblock is zero then we return a pointer to our parameter memory – which in this case is the address of our member float.  Memory referenced doesn’t have to be a member variable of course, often it is a reference directly to a requested memory record.  Sometimes objects will allocate one record but map several subblocks to the memory, spacing them out appropriately.  You are free to do what you want as long as you don’t reference global memory as your object has to support multiple instances.
      Likewise for this method the return for an error case is the default (0).  If the framework sees a 0 size record or nullptr returned from the subblock method it will return an error over xTP and not attempt to write out of bounds.  It will also return an error if address + size in the tuneXTP method exceeds the bounds dictated here. (Eg: subblock size is 16, but I want to write 8 bytes starting at address 12, this would be denied).
      Whether your data is defined in DDF as ‘Tuning’ or ‘State’ it still will have a subblock.  The following fields in GTT’s SV Viewer.
      In the above picture we can see how this information translates to the DDF side.
      SubBlockID is the same subblock as above.  Offset is your address within the subblock, size is the size of the variable.  You can also see above the category here is ‘Tuning’.  A subblock is either ‘Tuning’ or ‘State’ and  it cannot be split between them.
      If an audio object not require any sub-blocks (no tuning or state parameters), these methods don’t need to be overridden.
      « Basic Features and APIsSwitch Processing State »
      Suggest Edit
      • Careers
      • Contact
