//============================================================ // (C) 2017 Harman International Industries, Incorporated. // Confidential & Proprietary. All Rights Reserved. // ============================================================ /*! * file AwxiAudioObjExtMemRecs.cpp * brief Memory related description Source file * details Implements the audio object memory related API * details Project Extendable Audio Framework * copyright Harman/Becker Automotive Systems GmbH * 2020 * All rights reserved * author xAF Team */ /*! * include files required to request the dynamic memory */ #include "AwxAudioObjExtMemRecs.h" xUInt8 CAwxAudioObjExtMemRecs::getMemRecords(xAF_memRec* memTable, xAF_memRec& scratchRecord, xInt8 target, xInt8 format) { xUInt8 numMemRecords = (static_cast(ENABLE_BLOCK) == m_EnMemory) ? static_cast(NUM_MEM_RECORDS) : static_cast(FLOATARRAY); //m_Param memory memTable[PARAM].alignment = 4; memTable[PARAM].size = static_cast(static_cast(m_NumAudioIn) * NUM_PARAMS_PER_CHANNEL * sizeof(xFloat32)); memTable[PARAM].label = "Tuning Parameters"; //m_Coeff memory memTable[COEFF].size = static_cast(static_cast(m_NumAudioIn) * sizeof(xFloat32)); memTable[COEFF].alignment = 4; memTable[COEFF].label = "Gain Values"; //m_MemBlck memory(Abstracted Tuning Memory) if (static_cast(ENABLE_BLOCK) == m_EnMemory) { memTable[FLOATARRAY].size = FLOAT_ARRAY_SIZE * sizeof(xFloat32); memTable[FLOATARRAY].alignment = 4; memTable[FLOATARRAY].label = "Abstracted Tuning Memory values"; } return numMemRecords; }
