Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
  • Getting Started
  • User Guides
  • Developer Guides
Table of Content
  • 20
Audio Object Developer Guide
  1. Purpose of this Document
  2. Overview
    1. Audio Object Workflow
    2. Audio Object Class
  3. Audio Object Configuration
    1. Design Time Configuration
      1. Metadata
    2. Advanced Design Time Configuration
      1. Audio Object Memory
  4. Basic Features and APIs
  5. Advanced Features and APIs
    1. Switch Processing State
    2. Debug and Monitoring
    3. Background Method
  6. Audio object Example Object
    1. AO Example - AwxAudioObjExt.cpp
    2. AO Example - AwxAudioObjExtToolbox.cpp
    3. AO Example - AwxAudioObjExtMemRecs.cpp
    4. AO Example - AwxAudioObjExt.h
    5. AO Example - AwxAudioObjExtToolbox.h
    6. AO Example - AwxAudioObjExtMemRecs.h
  7. General Guidelines
  8. Adding External AO into AudioworX Package
  9. Building External Audio Object
Starter Kit Developer Guide
  1. Overview
  2. Assembling and Configuring Starter Kit Components
  3. Setting Up the Developer Environment
  4. SKUtility Developer Options
  5. Build AWX External Object
  6. Running Debug Session
xAF Integration User Guide
Troubleshooting
  1. GTT Installation
  2. GTT GUI Issues
  3. AmpSRV2
      6.4.AO Example - AwxAudioObjExt.h
      • Audio Object Developer Guide
      • AO Example - AwxAudioObjExt.h
      // (C) 2017 Harman International Industries, Incorporated.
      // Confidential & Proprietary. All Rights Reserved.
      *   file       AwxAudioObjExt.h
      *   brief      Simple demo object Audio object to start a development of a new audio object- Header file
      *   details    Project    Extendable Audio Framework
      *   copyright  Harman/Becker Automotive Systems GmbH
              2017
              All rights reserved
      *   author     xAF Team
      *   date       Nov 28, 2023
      #ifndef AWXAUDIOOBJEXT_H
      #define AWXAUDIOOBJEXT_H
      *   xaf mandataory includes
      #include "AudioObject.h"
      #define AWXAUDIOOBJEXT_VERSION_MAJOR             (0x01)
      #define AWXAUDIOOBJEXT_VERSION_MINOR             (0x01)
      #define AWXAUDIOOBJEXT_VERSION_REVISION          (0x06)
      #define AWXAUDIOOBJEXT_TUNING_VERSION_MAJOR      (0x01)
      #define AWXAUDIOOBJEXT_TUNING_VERSION_MINOR      (0x00)
      /** here you can add all required include files required for
          the core functionality of your objects
      #define AWX_AUDIO_OBJ_EXT_NUM_PARAMS         1
      #define FLOAT_ARRAY_SIZE                     10
      #define NUM_DIMENSION_VAR                    1
      *    brief Simple example object to provide a starting point for a new audio object
      class CAwxAudioObjExt : public CAudioObject
      public:
          static AOVersion version;
          CAwxAudioObjExt();
          virtual ~CAwxAudioObjExt();
          *   Refer AudioObject.h for description
           *   It returns the class size of the given audio object.
          xUInt32 getSize() const OVERRIDE;
           This function initializes all the object variables and parameters. In this method, the object shall initialize all its memory to appropriate values.
          void init() OVERRIDE;
          void calc(xAFAudio** inputs, xAFAudio** outputs) OVERRIDE;
           *    brief  This method is called when an object receives updated tuning data.
           *    param  subblock               index selects the subblock
           *    param  offsetBytes               points the offset in param memory (bytes)
           *    param  sizeBytes                   number of parameters to be updated (bytes)
           *    param  shouldAttemptRamp      whether or not this data should be attempt to apply instantly, or AO should attempt ramping
          void tuneXTP(xSInt32 subblock, xSInt32 adrBytes, xSInt32 sizeBytes, xBool shouldAttemptRamp) OVERRIDE;
      	*    brief  Retrieves pointer to the start of the subblock
      	*    param  subBlock subblock number
      	*    return start address of the subblock
          xInt8* getSubBlockPtr(xUInt16 subBlock) OVERRIDE;
      	*    Returns the size of the sub block indicated by 'subBlock'
      	*    param  subBlock the ID of the state subBlock we want to get the size of
      	*    return size of subBlock
          xSInt32 getSubBlockSize(xUInt16 subblock) OVERRIDE;
          *   Assigns the additional configuration as the object requires.
      	void assignAdditionalConfig() OVERRIDE;
           *    Control method to set the new value
           *    param index - pin index of the object's control input we are writing to
           *    param value - value we are writing
      	xSInt32 controlSet(xSInt32 index, xFloat32 param) OVERRIDE;
           *    brief  It reads the array of applied gain values through additional configuration "Max Gain per channel" for each channel.
           *    param    index  denotes the channel index
           *    return   Gain value read for each channel.
          xFloat32 getMaxGain(xSInt32 index);
      	enum AddnlVars {MAX_GAIN_PER_CHANNEL, THIRD_PARTY_MEM_BLK , AWX_EXT_NUM_ADD_VARS };
      	enum Modes { GAIN, GAIN_WITH_CONTROL, AWX_EXT_NUM_MODES };
      	enum MemAccess { DISABLE_BLOCK, ENABLE_BLOCK };
      	enum memoryRecords { PARAM, COEFF, FLOATARRAY, NUM_MEM_RECORDS } memRecs;
          enum PARAMS { NUM_PARAMS_PER_CHANNEL = 2 };
      	xInt8 m_EnMemory;
      protected:
          xFloat32* m_Coeffs;                                         ///< internal pointer to COEFF memrec
          xFloat32* m_Params;                                         ///< internal pointer to PARAM memrec
      	xFloat32* m_MemBlock;                                       ///< internal pointer to FLOATARRAY memrec
      private:
           *    brief  for each channel, checks the gain limits and calculates gain coefficient
           *    param    channel     channel index
           *    param    gainIndB    gain in dB
          void calcGain(xSInt32 channelIndex, xFloat32 gainIndB);
      #endif //AWXAUDIOOBJEXT_H
      « AO Example - AwxAudioObjExtMemRecs.cppAO Example - AwxAudioObjExtToolbox.h »
      Suggest Edit
      • Careers
      • Contact
