Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
  • Getting Started
  • User Guides
  • Developer Guides
Table of Content
  • 20
Audio Object Developer Guide
  1. Purpose of this Document
  2. Overview
    1. Audio Object Workflow
    2. Audio Object Class
  3. Audio Object Configuration
    1. Design Time Configuration
      1. Metadata
    2. Advanced Design Time Configuration
      1. Audio Object Memory
  4. Basic Features and APIs
  5. Advanced Features and APIs
    1. Switch Processing State
    2. Debug and Monitoring
    3. Background Method
  6. Audio object Example Object
    1. AO Example - AwxAudioObjExt.cpp
    2. AO Example - AwxAudioObjExtToolbox.cpp
    3. AO Example - AwxAudioObjExtMemRecs.cpp
    4. AO Example - AwxAudioObjExt.h
    5. AO Example - AwxAudioObjExtToolbox.h
    6. AO Example - AwxAudioObjExtMemRecs.h
  7. General Guidelines
  8. Adding External AO into AudioworX Package
  9. Building External Audio Object
Starter Kit Developer Guide
  1. Overview
  2. Assembling and Configuring Starter Kit Components
  3. Setting Up the Developer Environment
  4. SKUtility Developer Options
  5. Build AWX External Object
  6. Running Debug Session
xAF Integration User Guide
Troubleshooting
  1. GTT Installation
  2. GTT GUI Issues
  3. AmpSRV2
      6.5.AO Example - AwxAudioObjExtToolbox.h
      • Audio Object Developer Guide
      • AO Example - AwxAudioObjExtToolbox.h
      // (C) 2017 Harman International Industries, Incorporated.
      // Confidential & Proprietary. All Rights Reserved.
      *   file      AwxAudioObjExtToolbox.h
      *   brief     AwxAudioObj Audio Object Toolbox - Header file
      *   details   Project    Extendable Audio Framework
      *   copyright Harman/Becker Automotive Systems GmbH
             2017
             All rights reserved
      *   author    xAF Team
      *   date      March 28, 2023
      #ifndef AWXAUDIOOBJEXT_TOOLBOX_H
      #define AWXAUDIOOBJEXT_TOOLBOX_H
      *   xaf mandataory includes
      #include "AwxAudioObjExtMemRecs.h"
      #include "AudioObjectToolbox.h"
      #include "XafDefs.h"
      /** here you can add all required include files required for
          the core functionality of your objects
      class CAwxAudioObjExtToolbox : public CAudioObjectToolbox, public CAwxAudioObjExtMemRecs
      public:
          *    Default ctor / dtor to initialite member variables of the audio object
          CAwxAudioObjExtToolbox();
          virtual ~CAwxAudioObjExtToolbox();
          *    Returns the object description
          *    return pointer to structure describing object configuration.
          const tObjectDescription*   getObjectDescription() OVERRIDE;
           *    Writes object template information to the buffer returns number of bytes written
           *    param  info   audio object tuning info.
           *    param  buffer buffer for XML output.
           *    param  maxLen maximal length of the buffer.
           *    return size of generated xml file.
      	xUInt32 getXmlObjectTemplate(tTuningInfo* info, xInt8* buffer, xUInt32 maxLen) OVERRIDE;
           *    brief  Returns the overall object description used in the object
           *            within the device description file
           *    param  info pointer to TuningInfo structure
           *    param  buffer pointer to buffer used for file creation.
           *    param  maxlen max allowed size of generated file.
           *    return size of generated device.ddf file.
      	xUInt32 getXmlFileInfo (tTuningInfo* info, xInt8* buffer, xUInt32 maxLen) OVERRIDE;
          *    Returns the mode description of object
          *    param  mode    index of the selected mode
          *    return pointer to the object mode description
      	const tModeDescription* getModeDescription  (xUInt32 mode) OVERRIDE;
          *    This function sets the object configuration based on user settings indicated in GTT
          *    param  configOut   the configuration of the object sent back to the tool
          *    return error code
      	xAF_Error getObjectIo(ioObjectConfigOutput* configOut) OVERRIDE;
           *    Returns the additional variable description
           *    param  index   index of the additional parameter
           *    return instance of additional variable description
      	const additionalSfdVarDescription* getAdditionalSfdVarsDescription(xUInt32  index) OVERRIDE;
            *    brief  Creates metadata entries for the specific audio object
            *            this function must be overridden by each object supporting
            *            the metadata feature. Otherwise default data will be created.
      	void createStaticMetadata () OVERRIDE;
           *    brief  Creates mode and configuration dependent metadata entries for the specific audio object
           *    param  configIn  the configuration of audio in, out and num elements passed in by the design tool
          void createDynamicMetadata(ioObjectConfigInput& configIn, ioObjectConfigOutput& configOut) OVERRIDE;
      protected:
      #endif //AWXAUDIOOBJEXT_TOOLBOX_H
      « AO Example - AwxAudioObjExt.hAO Example - AwxAudioObjExtMemRecs.h »
      Suggest Edit
      • Careers
      • Contact
