Audio Object Example – AwxAudioObjExt.h
// (C) 2017 Harman International Industries, Incorporated.
// Confidential & Proprietary. All Rights Reserved.
*   file       AwxAudioObjExt.h
*   brief      Simple demo object Audio object to start a development of a new audio object- Header file
*   details    Project    Extendable Audio Framework
*   copyright  Harman/Becker Automotive Systems GmbH
        2017
        All rights reserved
*   author     xAF Team
*   date       Nov 28, 2023
#ifndef AWXAUDIOOBJEXT_H
#define AWXAUDIOOBJEXT_H
*   xaf mandataory includes
#include "AudioObject.h"
#define AWXAUDIOOBJEXT_VERSION_MAJOR             (0x01)
#define AWXAUDIOOBJEXT_VERSION_MINOR             (0x01)
#define AWXAUDIOOBJEXT_VERSION_REVISION          (0x06)
#define AWXAUDIOOBJEXT_TUNING_VERSION_MAJOR      (0x01)
#define AWXAUDIOOBJEXT_TUNING_VERSION_MINOR      (0x00)
/** here you can add all required include files required for
    the core functionality of your objects
#define AWX_AUDIO_OBJ_EXT_NUM_PARAMS         1
#define FLOAT_ARRAY_SIZE                     10
#define NUM_DIMENSION_VAR                    1
*    brief Simple example object to provide a starting point for a new audio object
class CAwxAudioObjExt : public CAudioObject
public:
    static AOVersion version;
    CAwxAudioObjExt();
    virtual ~CAwxAudioObjExt();
    *   Refer AudioObject.h for description
     *   It returns the class size of the given audio object.
    xUInt32 getSize() const OVERRIDE;
     This function initializes all the object variables and parameters. In this method, the object shall initialize all its memory to appropriate values.
    void init() OVERRIDE;
    void calc(xAFAudio** inputs, xAFAudio** outputs) OVERRIDE;
     *    brief  This method is called when an object receives updated tuning data.
     *    param  subblock               index selects the subblock
     *    param  offsetBytes               points the offset in param memory (bytes)
     *    param  sizeBytes                   number of parameters to be updated (bytes)
     *    param  shouldAttemptRamp      whether or not this data should be attempt to apply instantly, or AO should attempt ramping
    void tuneXTP(xSInt32 subblock, xSInt32 adrBytes, xSInt32 sizeBytes, xBool shouldAttemptRamp) OVERRIDE;
	*    brief  Retrieves pointer to the start of the subblock
	*    param  subBlock subblock number
	*    return start address of the subblock
    xInt8* getSubBlockPtr(xUInt16 subBlock) OVERRIDE;
	*    Returns the size of the sub block indicated by 'subBlock'
	*    param  subBlock the ID of the state subBlock we want to get the size of
	*    return size of subBlock
    xSInt32 getSubBlockSize(xUInt16 subblock) OVERRIDE;
    *   Assigns the additional configuration as the object requires.
	void assignAdditionalConfig() OVERRIDE;
     *    Control method to set the new value
     *    param index - pin index of the object's control input we are writing to
     *    param value - value we are writing
	xSInt32 controlSet(xSInt32 index, xFloat32 param) OVERRIDE;
     *    brief  It reads the array of applied gain values through additional configuration "Max Gain per channel" for each channel.
     *    param    index  denotes the channel index
     *    return   Gain value read for each channel.
    xFloat32 getMaxGain(xSInt32 index);
	enum AddnlVars {MAX_GAIN_PER_CHANNEL, THIRD_PARTY_MEM_BLK , AWX_EXT_NUM_ADD_VARS };
	enum Modes { GAIN, GAIN_WITH_CONTROL, AWX_EXT_NUM_MODES };
	enum MemAccess { DISABLE_BLOCK, ENABLE_BLOCK };
	enum memoryRecords { PARAM, COEFF, FLOATARRAY, NUM_MEM_RECORDS } memRecs;
    enum PARAMS { NUM_PARAMS_PER_CHANNEL = 2 };
	xInt8 m_EnMemory;
protected:
    xFloat32* m_Coeffs;                                         ///< internal pointer to COEFF memrec
    xFloat32* m_Params;                                         ///< internal pointer to PARAM memrec
	xFloat32* m_MemBlock;                                       ///< internal pointer to FLOATARRAY memrec
private:
     *    brief  for each channel, checks the gain limits and calculates gain coefficient
     *    param    channel     channel index
     *    param    gainIndB    gain in dB
    void calcGain(xSInt32 channelIndex, xFloat32 gainIndB);
#endif //AWXAUDIOOBJEXT_H
