Fader Design
Fader Horizontal
A Fader Horizontal is an adjustable horizontally-positioned fader control that manipulates a device parameter.
Controls can be managed in the Custom Panel designer and, once the Custom Panel is activated, utilized by the end user. This control must be linked to a parameter to function properly.
Fader Vertical
A vertical fader is an adjustable vertically-positioned control that manipulates a device parameter.
Fader Multi Parameter
A multiparameter fader manipulates multiple device parameters.
On an activated Custom Panel, levels on a multiparameter fader can be adjusted together or individually
Common Fader Design Properties
Properties Type
Description
General
  • Control Info: Shows control type. This propery is Read only.
  • Locked: Specifies if the control is locked out so that it cannot be moved or re-sized.
    • Checked = Locked
    • Unchecked = Unlocked
Parameters
  • Addresses: Enables panel designer to edit addressing information with the added benefit that the values can be validated as a group before being applied to the device.
    This editor also allows the user to assign multiple parameters to the control. Click to select Parameter Address Editor.
    • Properties correspond to the system explorer.
  • Information: Shows information about the Parameter Address.
    • Read only. Properties correspond to the system explorer
  • Maximum: Maximum parameter value.
    • The largest parameter value.
  • Minimum: Minimum parameter value.
    • The smallest parameter value.
  • Reset Text: Optional text to display in right click context popup.
Appearance
  • Location: Control location (in pixels) of the control on the Custom Panel. Change X (horizontal) and Y (vertical) values in relation to upper left corner.
    You can also drag the control to a different location
  • Size: Control size (in pixels). Change width and height values. You can also re-size the control manually
  • Background Image: Brings up the Select Background Image window
  • Background Color: Background color of the control
  • Tool Tip Text: The text that appears on control mouse-over.
  • Tab Index: Determines the position of the control in the tab order
  • Tab Stop: Specifies whether the control appears in the tab order.
    • Checked = Appears
    • Unchecked = Does not appear
Arrow
  • Maximum Arrows: The maximum number of arrows to display.
  • Arrow Direction: The direction the arrows should point.
    • Point Left or Point Right
Fader Cap
  • Fader Cap Image: The image displayed for the fader cap.
    • Click Browse to locate custom fader caps
  • Fader Cap Size: How large the fader cap will be
  • Arrow Box Width: The width of the arrow box in pixels
  • Vertical Offset: The vertical offset of the fader cap, in pixels, from the fader channel
  • Horizontal Offset: The horizontal offset of the fader cap, in pixels, from the fader channel
  • Hot Spot: Sets mouse sensitivity to the fader cap or the entire length of the slider
  • Highlight Color: The channel highlight color
  • Arrow Box Separation: The distance between the arrow box and the fader channel in pixels.
  • Label Margin: The amount of space, as a decimal fraction of the width of the control, between the center channel and the tick marks
Channel
  • Channel Color: Color of the fader channel. Default is Dim Gray
  • Channel Width: Width of the fader channel in pixels
  • Channel Start: Distance, as a percentage of length, from the bottom or left edge to where the fader channel will start.
  • Channel End: Distance, as a percentage of length, from the bottom or left edge to where the fader channel will end.
  • Channel Center: Distance, as a percentage of width, from the bottom or left edge to where the fader channel will be located.
Scale
  • Display Tick Marks: Option to display the tick marks of the control. Must be set to true for custom ticks to display.
    • Checked = Display
    • Unchecked = Do not display
  • Number of Major Ticks: How many major ticks are displayed.
  • Tick Location: The location of the tick marks relative to the fader channel.
  • Custom Ticks: Whether to use custom tick values by utilizing the scale editor or not.
    • Checked = Display
  • Display Tick Values: The value of the ticks to be displayed.
  • Value Format: The format of the tick values.
  • Labels Inside:
  • Major Tick Color: The color of the major tick.
  • Major Tick Length: The length of the major tick.
  • Number of Minor Ticks: How many minor ticks are displayed.
  • Minor Tick Color: The color of the minor tick.
  • Minor Tick Length: The length of the minor tick.
  • Font: The font for the ticks.
  • Labels Inside: Whether labels are drawn between tick marks and fader channel.
    Whether labels are drawn between tick marks and fader channel or not.
    • Checked = labels drawn between tick marks and channel.
    • Unchecked = tick marks drawn between labels and channel.
  • Labels Vertical: Whether labels are displayed vertically or horizontally.
    • Checked = labels display vertically
    • Unchecked = labels display horizontally, left to right.
  • Label Margin: The amount of space, as a decimal fraction of the width of the control, between the center channel and the tick marks.
Nudge Button
  • Nudge Button Location: Location of the nudge buttons.
    • None, Center, Above or Below
  • Nudge Type: Determines, with the increment amount, how much the control will adjust when a nudge button is pressed.
    • Percent – percentage of the total visual display of the control. For non-logarithmic controls, the visual display and the total value of the control will be the same. For logarithmic controls, the visual display will differ from the total value.
    • Bump – small increment
    • Value – specified increment amount.
  • Increment Amount: Determines, with the nudge type, how much the control will adjust when a nudge button is pressed.
  • Nudge Button Separation: Distance, in pixels, from the edge to the nudge button.
  • Up Image: The static image for the “up” nudge button. Click the button to select a new image.
  • Up Pushed Image: The image that displays when the “up” nudge button is pushed. Click the button to select a new image.
  • Down Image: The static image for the “down” nudge button. Click the button to select a new image.
  • Down Pushed Image: The image that displays when the “down” nudge button is pushed. Click the button to select a new image.
Popup Value
  • Popup Value Position – Fraction: The location of the popup value as a decimal fraction of the width (X) and height (Y) of the control.
  • Display Popup Value: Displays the value of the control in a popup, if set to true
    • Checked = Display
