Graph Parameters Window
  • Channel Setup: Brings up the Channel Setup window.
  • Reset Graph: Resets the graph back to its default state.
  • Parameter Setup
    • Current Channel: Select the current channel to edit.
    • Current Curve: Select the process for the channel that was selected above.
    • Addresses: Brings up the Parameter Address Editor window.
Channel Setup Window
Graphical user interface, application Description automatically generated
  • Number of Channels: Click the up/down arrows to select the number of channels.
  • PEQ per channel: Click the up/down arrows to select the number of parametric equalizers per channel
  • Xover/Bandpass per channel: Click the up/down arrows to select the number of crossover / bandpass filters per channel.
  • DeEsser per channel: Click the up/down arrows to select the number of DeEsser filters per channel.
  • FIR per channel: When available, Click the up/down arrows to select the number of FIR filters per channel.
  • Bandpass in Selector: When checked, displays the Bandpass in the graph.
  • Color Scheme: Choose the color scheme for the graph. Select from Channel Number, Band Number or Curve Index
