The Measurement Module is used to perform synchronous and asynchronous impulse response measurements and recordings.
If you want to work with the Measurement Module, you don’t need an active project. GTT will automatically create da ummy project, where you can perform all the operations. In case there is an active project available, the Measurement Module session will be associated with it.
A device is not necessary for the Measurement Module to function in the project. The Measurement Module enables direct sound card measurements without an intermediate device, whereas tests controlled by gain channels can be carried out via a device.
Related Topics
