Q. What is the range supported for BlockID?
A. For audio objects with extended block id support, block id should be in the range – 33024 to 65280 in multiples of 256.
Q. Not able to load the audio library (VirtualAmp.dll or Toolbox dll)
A. If VirtualAmp.dll depends on another dll which is not part of GTT, GTT will fail to load the dll. In this case user needs to copy the dependent dlls to C:\Program Files\Harman\HarmanAudioworX\tools\GTT folder.
Q. GTT stops the audio from other application when launched?
A. GTT doesn’t stops audio from other application, However If user face any such difficulty.
Change the properties of the sound settings in your laptop/ PC. Uncheck the check box which says, “Allow application to take exclusive control of device.”
