The table below outlines the xAF know issues.
| Issues/ Limitations | Description |
| VST only issues/Limitations | The input and output sample rates of the VST must always be 48000 Hz so any audio core with inputs/outputs connected to the device input/output should also be connected to core objects at 48000 Hz. |
| IVP | Using Block Length <1024 with MME driver in sound card settings will have dropouts. Use Asio or block length greater than or equal to 1024. |
