A search box is available on the top right of the window to search parameter sets by Audio-object name.
To enable the search, at least 3 characters must be entered. When an audio object’s name is searched, any matching audio objects that contain the key are highlighted in yellow, and a navigation to the first matching row is automatically carried out.
You can use “<< and >>” options to navigate between the highlighted audio objects.
If a row is added or removed from parameter sets, and if a set group is changed, the search results will be cleared.
You can sort the explorer data using “Sort By Name” or “Sort By HiQNetld”.
