Streaming
You can stream live data from the device. The state variables which support streaming and polling are displayed in the state variable explorer tree with “Category” other than “Tuning”.
The streaming and polling are used to monitor the signal flow of different parameters in a Signal Flow Designer.
Streaming can be beneficial when you need to constantly monitor a signal for a specific channel. If any changes are made to the signal flow design, the updated values will automatically be displayed through streaming. However, for non-streamable parameters, GTT will transmit a single command and receive the corresponding value from the device in response.
To access this feature, you will need a license for unlocking. Kindly contact the license administrator to obtain the necessary license.
The object tree displays filtered state variables that support streaming and polling.
Streaming state variables are highlighted in white, while polling state variables are highlighted in orange.
The default display of state variables in the object tree is set to show “after calculation” data for streaming out. However, if you want to display “before calculation” state variables, select the “Display IN Channels” option. The IN state variables indicated with a blue color and OUT state variables indicated with a red color, with keywords denoting their specified type.
Below table describes the audio objects that support streaming.
Audio Object Parameter Name State Variable Streamable
Level Monitor Level_Value Yes True
Compressor Attenuation Yes True
VNC Control VNCControlStates Yes True
NoiseESt StreamingParam Yes True
AlaControl AlaControlStates Yes True
FFTCalc FFTCalcState Yes True
Ducker State params Yes True
dbXLimiter States Yes True
AudioToControl AudioToControlState Yes True
Limiter Attenuation Yes True
Configure Streaming
If you want to stream streamable state variable, then you can enable Streaming option.
To enable Streaming per core:
  1. Open the Device View and select the Virtual core layer of the device.
  2. Go the Virtual core properties, select the Streaming checkbox, and set a number of State Variables per core.
Maximum 32 state variables can be configured for streaming.
If you want to perform the operation using non-streamable state variables, then there is no need to enable these options
