Trace Functionalities
Select/ Deselect All Traces
At the top of the Traces view, there is a checkbox that enables you to either select or deselect all traces. When you select the checkbox at the top, all traces within the trace window will be automatically selected. Similarly, when the top checkbox is deselected, it will unselect all the traces in the trace window.
When the top checkbox in the upper trace window is selected in linking mode, it automatically selects all the traces from both the upper and lower trace windows. Similarly, when the top checkbox in the upper trace window is unselected, it will unselect all the traces from both the upper and lower trace windows.
Lock / Unlock Traces
When the trace is locked, the recapture on that trace is disabled. Once unlocked the trace can be recaptured. This button toggles between locked and unlocked states.
Recapture Traces
The trace can be recaptured from the signal for the same channel using this option.
Select / Unselect Trace
The trace can be made visible and hidden on the graph using this option.
Show Measurement
The measurements can be shown on the graph for the trace using this option.
