Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
  • Getting Started
  • User Guides
  • Developer Guides
Table of Content
Global Tuning Tool
  1. About Global Tuning Tool
    1. System Requirements
  2. Workspace Overview
    1. Home Screen
      1. Home screen Options
      2. Application Options
    2. Device Designer Overview
      1. Tools
      2. Connection
      3. Import and Export
      4. Tuning
      5. Device Panels
    3. Devices and Template View
    4. Core Objects Toolbox
    5. Device Operations
    6. Properties Panel
    7. Device View
    8. Help
  3. Configurations
    1. Configure State Variable
      2. Core Object Settings
      3. Custom Actions Settings
      5. Maintain Folder Structure
      7. Handling Dual Responses
      8. Send Preset Data Online
    4. Link Window
    5. Configure Controller
    6. Launch MIPS Profiling
    7. Launch Memory Profiling
    8. Editing Memory Latency
      1. Start Live Streaming
      2. Record Streaming Data
      3. FFT for Streaming
    10. Configure File controller
    11. Configure Control IDS
    12. Custom Device Usage
    13. Multi-xAF Library Support
  4. Operations
    1. Create a New Project
    2. Create Signal Flow
    3. Connecting a Device
    4. Routing (Connections)
    5. Device Synchronization
    7. Tune a Signal Flow
Signal Flow Designer
    1. Pin Labelling
    2. View Audio Object Metadata
    4. Upgrade Audio Object
    6. Metering the Signal Flow
    7. Copy and Paste Operation
    8. Undo and Redo Operation
    9. Block Control
    11. Securing Audio Objects
  4. Create a Signal Flow
  5. Tune a Signal Flow
  6. Native Panels
    1. Launching Native Panel
  11. Compound Audio Object
    2. Import and Export CAO
    3. Tuning and Editing CAO
    4. Create Preset for CAO
    5. Edit CAO Instance
    6. Set password for CAO
    8. Multi dll support for CAO
Audio Object Description
  2. Audio Object General Information
  3. Interface Objects
    1. AudioIO
    2. ControlIn
    3. ControlOut
  4. Basic Objects
    1. Delay
      1. Delay Panel
    2. Gain
      1. Gain Panel
    3. Level Monitor
      1. Level Monitor Panel
    4. FaderBalance
      1. Fader Balance Panel
    5. Volume and Mute
      1. Volume and Mute Panel
    6. VolumeLite
  5. Control Objects
    1. Control Math
    2. Control Grouper
    3. Control GroupSplitter
    4. Control Multi Adder
    5. Control Mixer
      1. Control Mixer Panel
    6. Control Router
      1. Control Router Panel
    7. Control Smooth
    8. AudioToControl
    9. Lookup Table (LUT)
      1. Lookup Table (LUT) Panel
    10. Rate Control
    11. Control Generator
    12. Control Demux
  6. Routing Objects
    1. Router
      1. Router Panel
    2. Splitter
    3. Demux
    4. Selector
  7. Source Objects
    1. Noise Generator
      1. Noise Generator Panel
    2. Wave Generator
    3. FilePlayer
  8. Mixer Objects
    1. Adder
    2. Matrix Mixer
      1. Matrix Mixer Panel
    3. Merger
    4. Fader Matrix
      1. Fader Matrix Panel
  9. Dynamic Object
    1. Limiter
      1. Limiter Panel
  10. Filter Objects
    1. Filter Objects General Information
    2. ParameterBiquad
      1. Parameter Biquad Panel
    3. CoefficientBiquad
    4. Tone Control Extended
    5. XoverBiquad
      1. Xover Biquad Panel
    6. FastConv
      1. Fast Conv Panel
    7. FIR Filter
      1. FIR Filter Panel
  11. Core Objects Toolbox
Panel Designer
  1. Panel Designer Overview
  2. Panel Designer Components
    1. Panel Designer Ribbon
      1. Text Design
      2. Fader Design
      3. Rotary Design
      4. Button Design
      5. Box Design
      6. LED Design
      7. Meter Design
      8. Other Design
      9. Images
      10. Advanced
    2. Panels View
    4. Designer Workspace
    5. Editor Windows
      1. Parameter Address Editor
      3. System Function Editor
      5. Select Color Window
      6. Discrete Values Editor
      8. LED Values Editor
      9. Graph Parameters Window
      10. Scale Editor
  3. Create a Custom Panel in GTT
  4. Switch between Multiple Parameter Sets
Parameter Set
  1. Parameter Set Overview
  2. Parameter Set Components
    1. Apply Delta in Parameter Sets
    2. Retrieve and Verify Parameter Sets
    3. Importing and Exporting Set File
    4. Preset Comparison
  3. Create a Parameter Set in GTT
Real Time Analyzer
  3. Settings
    1. Channels Settings
    2. Generator Settings
    3. Analyzer Settings
    4. Microphone Calibration
    5. RTA Advanced Settings
      1. Sound Card Settings
      2. Plugin Host Setting
      3. Advanced Analyzer Settings
      4. Advanced Generator Settings
      5. Graph Display Settings
      6. Mimo Convolver Settings
      7. Recorder Settings
      8. Routing Settings
  5. Probe Point Configuration
  6. Real Time Data View
  8. Traces
    1. Trace Toolbar
    2. Trace Configuration
    3. Trace Functionalities
    4. Offline Traces Anlaysis
    5. RTA Shortcuts
  9. Analysing Audio Signal
Measurement Module 2.0
  2. Configurations
    1. Device Output Mapping
    2. Generator
    3. Test Sound
    1. Scene Setup
    2. Speaker Configuration
    3. Microphone Configuration
    4. Define Measurement
      1. Define Mannequin Measurement
    5. Measurement Session
  4. Performing Measurement
Central Viewer
  1. Central Viewer Overview
  2. Central Viewer Window
    1. Configurations
    2. Scene Mode
    3. Chart Selector
    4. Waterfall Chart
    5. Graph Area
    6. Curve Lists
    7. Domain Selector
Starter Kit Utility Tool
  1. Starter Kit Utility Tool (SKUtility) Overview
  2. SKUtility Tool - Graphical Application
  3. SKUtility Tool - Command-Line Interface
    1. Useful Commands for Starter Kit
  4. Starter Kit Troubleshooting
3.3.3.Custom Actions Settings
  • Global Tuning Tool
  • Custom Actions Settings
The Preset Controller allows you to configure a “Custom Action” option. Choosing this option opens a dedicated configuration window where you can define custom actions, as shown in the below image.
In Preset controller, there is an option to configure what actions have to be performed when a slot is loaded.  Currently this feature supports the following actions.
  • Custom xTP command
  • Custom xTP command (External)
  • Set master control pin
  • Set Audio object processing state
  • Set control pin refresh.
These custom actions can be configured at different stages of slot load.  There are 4 stage that can be configured as listed below.
  1. Before slot load
  2. After fade out but before preset load
  3. After preset load but before fade in
  4. After slot load
Steps to configure custom actions:
  1. On the Custom action configuration window, click Add to add an action that you can configure.
  2. Once the action is added, select the “Stage” from the drop-down options.
  3. Similarly, select the “Action” from the drop-down actions.
  4. Click on Configure to configure the Action.
The data configuration option depend on the type of “Action” you choose from the drop-down. Below are the configurations for each supported action type.
Custom xTP command This action sends an xTP message of your choice into the device (as if it received it from GTT).
The commands which go to the core may send a response to the network after processing.  These responses may not cause a GTT update depending on the command.  The same limitation applies to read commands, for example reading a control value won’t cause GTT to update the value in the explorer.
You can select a xTP command from the drop-down. If the command is not available (perhaps in that case you are using a custom command), you can enter command Id in the text box.  Then you can enter the command data in the box provided.
This window lets you enter data in hexadecimal format. As you enter the data, the count at the bottom keeps track of the characters, helping you ensure the correct length.
To prevent mistakes, the system checks if the data is valid when you click “OK.” For your reference, the window also shows the current slot, stage, and specific action you are configuring.
The system automatically generates a clear description to help you understand the configured custom action.
Custom xTP command (External) This sends a command from the system to the extrenal device or any connected tool from the context of the xTP Interpreter.
You can select a xTP command from the drop-down. If the command is not available, you can enter command Id in the text box.  Then you can enter the command data in the box provided.
Set master control pin This is equivalent to sending the control and value from GTT or from any other xTP source.
This window appears when you choose “Set master control pin” as the action in the main custom action configuration window.
It will list the control pins configured in the signal flow.  You can select a control pin and enter value for the control pin.
Click “Ok” to save the configuration.The system automatically generates a clear description to help you understand the configured custom action.
Set Audio object processing state (beta) Sets the selected audio object to the chosen state.
This window appears when you choose “Set audio object processing state” as the action in the main custom action configuration window.
This window will show where you can configure the processing state of the audio object. Once the values are selected, Click “Ok” to save the processing state information.
Set control pin refresh Select the action -> Set control pin refresh in the action dropdown.
When the slot is loaded, select the control pin that needs to be refreshed.
This data will be sent to device as part of slot map. When the slot with this data is loaded, the configured custom action will be executed on the set control pin.
Once all the slots are configured with set of actions, the custom action window will appear as per below image.  You can override the default descriptions yourself after you configure the action.
The custom action data configured will be saved only when “Save and close” button is clicked in main custom action window.
« Core Object SettingsExporting Preset Configurations »
Suggest Edit
  • Careers
  • Contact
