Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
  • Getting Started
  • User Guides
  • Developer Guides
Table of Content
Global Tuning Tool
  1. About Global Tuning Tool
    1. System Requirements
  2. Workspace Overview
    1. Home Screen
      1. Home screen Options
      2. Application Options
    2. Device Designer Overview
      1. Tools
      2. Connection
      3. Import and Export
      4. Tuning
      5. Device Panels
    3. Devices and Template View
    4. Core Objects Toolbox
    5. Device Operations
    6. Properties Panel
    7. Device View
    8. Help
  3. Configurations
    1. Configure State Variable
      2. Core Object Settings
      3. Custom Actions Settings
      5. Maintain Folder Structure
      7. Handling Dual Responses
      8. Send Preset Data Online
    4. Link Window
    5. Configure Controller
    6. Launch MIPS Profiling
    7. Launch Memory Profiling
    8. Editing Memory Latency
      1. Start Live Streaming
      2. Record Streaming Data
      3. FFT for Streaming
    10. Configure File controller
    11. Configure Control IDS
    12. Custom Device Usage
    13. Multi-xAF Library Support
  4. Operations
    1. Create a New Project
    2. Create Signal Flow
    3. Connecting a Device
    4. Routing (Connections)
    5. Device Synchronization
    7. Tune a Signal Flow
Signal Flow Designer
    1. Pin Labelling
    2. View Audio Object Metadata
    4. Upgrade Audio Object
    6. Metering the Signal Flow
    7. Copy and Paste Operation
    8. Undo and Redo Operation
    9. Block Control
    11. Securing Audio Objects
  4. Create a Signal Flow
  5. Tune a Signal Flow
  6. Native Panels
    1. Launching Native Panel
  11. Compound Audio Object
    2. Import and Export CAO
    3. Tuning and Editing CAO
    4. Create Preset for CAO
    5. Edit CAO Instance
    6. Set password for CAO
    8. Multi dll support for CAO
Audio Object Description
  2. Audio Object General Information
  3. Interface Objects
    1. AudioIO
    2. ControlIn
    3. ControlOut
  4. Basic Objects
    1. Delay
      1. Delay Panel
    2. Gain
      1. Gain Panel
    3. Level Monitor
      1. Level Monitor Panel
    4. FaderBalance
      1. Fader Balance Panel
    5. Volume and Mute
      1. Volume and Mute Panel
    6. VolumeLite
  5. Control Objects
    1. Control Math
    2. Control Grouper
    3. Control GroupSplitter
    4. Control Multi Adder
    5. Control Mixer
      1. Control Mixer Panel
    6. Control Router
      1. Control Router Panel
    7. Control Smooth
    8. AudioToControl
    9. Lookup Table (LUT)
      1. Lookup Table (LUT) Panel
    10. Rate Control
    11. Control Generator
    12. Control Demux
  6. Routing Objects
    1. Router
      1. Router Panel
    2. Splitter
    3. Demux
    4. Selector
  7. Source Objects
    1. Noise Generator
      1. Noise Generator Panel
    2. Wave Generator
    3. FilePlayer
  8. Mixer Objects
    1. Adder
    2. Matrix Mixer
      1. Matrix Mixer Panel
    3. Merger
    4. Fader Matrix
      1. Fader Matrix Panel
  9. Dynamic Object
    1. Limiter
      1. Limiter Panel
  10. Filter Objects
    1. Filter Objects General Information
    2. ParameterBiquad
      1. Parameter Biquad Panel
    3. CoefficientBiquad
    4. Tone Control Extended
    5. XoverBiquad
      1. Xover Biquad Panel
    6. FastConv
      1. Fast Conv Panel
    7. FIR Filter
      1. FIR Filter Panel
  11. Core Objects Toolbox
Panel Designer
  1. Panel Designer Overview
  2. Panel Designer Components
    1. Panel Designer Ribbon
      1. Text Design
      2. Fader Design
      3. Rotary Design
      4. Button Design
      5. Box Design
      6. LED Design
      7. Meter Design
      8. Other Design
      9. Images
      10. Advanced
    2. Panels View
    4. Designer Workspace
    5. Editor Windows
      1. Parameter Address Editor
      3. System Function Editor
      5. Select Color Window
      6. Discrete Values Editor
      8. LED Values Editor
      9. Graph Parameters Window
      10. Scale Editor
  3. Create a Custom Panel in GTT
  4. Switch between Multiple Parameter Sets
Parameter Set
  1. Parameter Set Overview
  2. Parameter Set Components
    1. Apply Delta in Parameter Sets
    2. Retrieve and Verify Parameter Sets
    3. Importing and Exporting Set File
    4. Preset Comparison
  3. Create a Parameter Set in GTT
Real Time Analyzer
  3. Settings
    1. Channels Settings
    2. Generator Settings
    3. Analyzer Settings
    4. Microphone Calibration
    5. RTA Advanced Settings
      1. Sound Card Settings
      2. Plugin Host Setting
      3. Advanced Analyzer Settings
      4. Advanced Generator Settings
      5. Graph Display Settings
      6. Mimo Convolver Settings
      7. Recorder Settings
      8. Routing Settings
  5. Probe Point Configuration
  6. Real Time Data View
  8. Traces
    1. Trace Toolbar
    2. Trace Configuration
    3. Trace Functionalities
    4. Offline Traces Anlaysis
    5. RTA Shortcuts
  9. Analysing Audio Signal
Measurement Module 2.0
  2. Configurations
    1. Device Output Mapping
    2. Generator
    3. Test Sound
    1. Scene Setup
    2. Speaker Configuration
    3. Microphone Configuration
    4. Define Measurement
      1. Define Mannequin Measurement
    5. Measurement Session
  4. Performing Measurement
Central Viewer
  1. Central Viewer Overview
  2. Central Viewer Window
    1. Configurations
    2. Scene Mode
    3. Chart Selector
    4. Waterfall Chart
    5. Graph Area
    6. Curve Lists
    7. Domain Selector
Starter Kit Utility Tool
  1. Starter Kit Utility Tool (SKUtility) Overview
  2. SKUtility Tool - Graphical Application
  3. SKUtility Tool - Command-Line Interface
    1. Useful Commands for Starter Kit
  4. Starter Kit Troubleshooting
3.3.4.Exporting Preset Configurations
  • Global Tuning Tool
  • Exporting Preset Configurations
You can export Preset Configuration using the following methods:
  • Export Slot Map: To save the flash files of the slot map in the selected path with the provided name.
  • Export Set Files: To save all the set files of the map in the selected path.
  • Export All Files: To save all the set files of the map, along with the flash file and preset size information file in the selected path.
Right-click or click on “Export Options” to select the type of export.
To export a slot map set file, all files should contain at least one valid slot; otherwise, the options Export Slot Map, Export Set Files, Export All Files, and Export Slot will be disabled.
Exporting human readable flash file: The exported flash file can be helpful in case any slot gets accidentally deleted. You can reconfigure Preset Controller values using the slot map table details mentioned in the exported flash file.
Once you have configured all parameters of the Preset Controllers, it is recommended that you export the flash file.
Steps to export human human-readable flash file:
  1. Open Preset Controller, add and configure the slots.
  2. Click on the Configure and enable or disable “Ramp Setting”.
  3. Click on Export All Files, browse the desired location, and click Ok.
    This action creates a set map file, human-readable set map file in the CSV format, a preset size information file, and set files at the specified path.
    The name of the CSV file is determined by the name of the flash file, which is the original file.
    Example: The flash file name in the example below screenshot is Map.flash, so the created readable CSV file name is Map.flashr.
  4. Click on Export Slot Map, browse the desired location, enter the file name, and click Save.
    This action creates two files, one human-readable CSV file and another flash file with the specified name at the specified path.
    Open the CSV file to see the slot details.
    In the below image, the Ramp Setting details for “1: Core 0” column is “0:0 Disabled 1:0 Enabled 1:1 Enabled”, which is “Core Id : Instance ID : State” .
    The image below explains the “Ramp Setting” configuration for “0:0 Enabled 0:1 Enabled 0:1 Disabled” in the GTT.
    Similarly, all ramp settings details will be exported in this format.
  5. Click on Export Set Files, browse the desired location, and click Ok.
    This action automatically creates folder(s) with the set group name at the specified path.
    This set group folder contains exported set files.
« Custom Actions SettingsMaintain Folder Structure »
Suggest Edit
  • Careers
  • Contact
