Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
  • Getting Started
  • User Guides
  • Developer Guides
Table of Content
Global Tuning Tool
  1. About Global Tuning Tool
    1. System Requirements
  2. Workspace Overview
    1. Home Screen
      1. Home screen Options
      2. Application Options
    2. Device Designer Overview
      1. Tools
      2. Connection
      3. Import and Export
      4. Tuning
      5. Device Panels
    3. Devices and Template View
    4. Core Objects Toolbox
    5. Device Operations
    6. Properties Panel
    7. Device View
    8. Help
  3. Configurations
    1. Configure State Variable
      2. Core Object Settings
      3. Custom Actions Settings
      5. Maintain Folder Structure
      7. Handling Dual Responses
      8. Send Preset Data Online
    4. Link Window
    5. Configure Controller
    6. Launch MIPS Profiling
    7. Launch Memory Profiling
    8. Editing Memory Latency
      1. Start Live Streaming
      2. Record Streaming Data
      3. FFT for Streaming
    10. Configure File controller
    11. Configure Control IDS
    12. Custom Device Usage
    13. Multi-xAF Library Support
  4. Operations
    1. Create a New Project
    2. Create Signal Flow
    3. Connecting a Device
    4. Routing (Connections)
    5. Device Synchronization
    7. Tune a Signal Flow
Signal Flow Designer
    1. Pin Labelling
    2. View Audio Object Metadata
    4. Upgrade Audio Object
    6. Metering the Signal Flow
    7. Copy and Paste Operation
    8. Undo and Redo Operation
    9. Block Control
    11. Securing Audio Objects
  4. Create a Signal Flow
  5. Tune a Signal Flow
  6. Native Panels
    1. Launching Native Panel
  11. Compound Audio Object
    2. Import and Export CAO
    3. Tuning and Editing CAO
    4. Create Preset for CAO
    5. Edit CAO Instance
    6. Set password for CAO
    8. Multi dll support for CAO
Audio Object Description
  2. Audio Object General Information
  3. Interface Objects
    1. AudioIO
    2. ControlIn
    3. ControlOut
  4. Basic Objects
    1. Delay
      1. Delay Panel
    2. Gain
      1. Gain Panel
    3. Level Monitor
      1. Level Monitor Panel
    4. FaderBalance
      1. Fader Balance Panel
    5. Volume and Mute
      1. Volume and Mute Panel
    6. VolumeLite
  5. Control Objects
    1. Control Math
    2. Control Grouper
    3. Control GroupSplitter
    4. Control Multi Adder
    5. Control Mixer
      1. Control Mixer Panel
    6. Control Router
      1. Control Router Panel
    7. Control Smooth
    8. AudioToControl
    9. Lookup Table (LUT)
      1. Lookup Table (LUT) Panel
    10. Rate Control
    11. Control Generator
    12. Control Demux
  6. Routing Objects
    1. Router
      1. Router Panel
    2. Splitter
    3. Demux
    4. Selector
  7. Source Objects
    1. Noise Generator
      1. Noise Generator Panel
    2. Wave Generator
    3. FilePlayer
  8. Mixer Objects
    1. Adder
    2. Matrix Mixer
      1. Matrix Mixer Panel
    3. Merger
    4. Fader Matrix
      1. Fader Matrix Panel
  9. Dynamic Object
    1. Limiter
      1. Limiter Panel
  10. Filter Objects
    1. Filter Objects General Information
    2. ParameterBiquad
      1. Parameter Biquad Panel
    3. CoefficientBiquad
    4. Tone Control Extended
    5. XoverBiquad
      1. Xover Biquad Panel
    6. FastConv
      1. Fast Conv Panel
    7. FIR Filter
      1. FIR Filter Panel
  11. Core Objects Toolbox
Panel Designer
  1. Panel Designer Overview
  2. Panel Designer Components
    1. Panel Designer Ribbon
      1. Text Design
      2. Fader Design
      3. Rotary Design
      4. Button Design
      5. Box Design
      6. LED Design
      7. Meter Design
      8. Other Design
      9. Images
      10. Advanced
    2. Panels View
    4. Designer Workspace
    5. Editor Windows
      1. Parameter Address Editor
      3. System Function Editor
      5. Select Color Window
      6. Discrete Values Editor
      8. LED Values Editor
      9. Graph Parameters Window
      10. Scale Editor
  3. Create a Custom Panel in GTT
  4. Switch between Multiple Parameter Sets
Parameter Set
  1. Parameter Set Overview
  2. Parameter Set Components
    1. Apply Delta in Parameter Sets
    2. Retrieve and Verify Parameter Sets
    3. Importing and Exporting Set File
    4. Preset Comparison
  3. Create a Parameter Set in GTT
Real Time Analyzer
  3. Settings
    1. Channels Settings
    2. Generator Settings
    3. Analyzer Settings
    4. Microphone Calibration
    5. RTA Advanced Settings
      1. Sound Card Settings
      2. Plugin Host Setting
      3. Advanced Analyzer Settings
      4. Advanced Generator Settings
      5. Graph Display Settings
      6. Mimo Convolver Settings
      7. Recorder Settings
      8. Routing Settings
  5. Probe Point Configuration
  6. Real Time Data View
  8. Traces
    1. Trace Toolbar
    2. Trace Configuration
    3. Trace Functionalities
    4. Offline Traces Anlaysis
    5. RTA Shortcuts
  9. Analysing Audio Signal
Measurement Module 2.0
  2. Configurations
    1. Device Output Mapping
    2. Generator
    3. Test Sound
    1. Scene Setup
    2. Speaker Configuration
    3. Microphone Configuration
    4. Define Measurement
      1. Define Mannequin Measurement
    5. Measurement Session
  4. Performing Measurement
Central Viewer
  1. Central Viewer Overview
  2. Central Viewer Window
    1. Configurations
    2. Scene Mode
    3. Chart Selector
    4. Waterfall Chart
    5. Graph Area
    6. Curve Lists
    7. Domain Selector
Starter Kit Utility Tool
  1. Starter Kit Utility Tool (SKUtility) Overview
  2. SKUtility Tool - Graphical Application
  3. SKUtility Tool - Command-Line Interface
    1. Useful Commands for Starter Kit
  4. Starter Kit Troubleshooting
3.9.3.FFT for Streaming
  • Global Tuning Tool
  • FFT for Streaming
FFT Analysis capabilities are also available in the streaming window, wherein the FFT analysis of incoming audio signals is undertaken in real-time, depending upon the block size, additional calculations, etc).
The “Display Type” selection under the General tab provides the option to switch between Time and Frequency domain display.
When the Display Type is set to “Frequency Domain”, the Spectrum functionality of Streaming can be viewed.
In Spectrum view the X-axis ranges from “0 to Sampling Frequency / 2”, and Y-Axis ranges from “0 to -90 dbFS”.
Providing the correct sampling frequency is the responsibility of the audio engineer, and it should match the sampling frequency of the streaming state variable.
The Spectrum properties such as Block size, Sampling Frequency, Smoothing, and Averaging can be configured according to your requirements.
The variable “MaxWinSize” determines the maximum window size for smoothing in the Spectrum functionality. It has three options: Low (20), Medium (40), and High (1000). Choosing a larger number will result in a smoother curve.
For instance, if you set the limit to 500 Hz, all bins in the upper frequency range will be smoothed by averaging a window width of 500 Hz.
Example: Smoothing set to Off.
Example: Smoothing set to Low.
Example: Smoothing set to Medium.
Example: Smoothing set to High.
« Record Streaming DataConfigure File controller »
Suggest Edit
  • Careers
  • Contact
