AUDIOWORX
Home
Documentation
Videos
Release Notes
Login
AUDIOWORX
Home
Documentation
Videos
Release Notes
Login
AUDIOWORX
Home
Documentation
Videos
Release Notes
Login
Getting Started
User Guides
Developer Guides
Choose Version
Table of Content
Global Tuning Tool
About Global Tuning Tool
System Requirements
Global Tuning Tool Workflow
Workspace Overview
Home Screen
Home screen Options
Application Options
Device Designer Overview
Tools
Connection
Import and Export
Tuning
Device Panels
Devices and Template View
Core Objects Toolbox
Device Operations
Properties Panel
Device View
Help
Configurations
Configure State Variable
Configure Default Control-Ids
Configure Preset Controller
Configuring Controller Slot
Core Object Settings
Custom Actions Settings
Exporting Preset Configurations
Maintain Folder Structure
Loading Slots on the Device
Handling Dual Responses
Send Preset Data Online
Link Window
Configure Controller
Launch MIPS Profiling
Launch Memory Profiling
Editing Memory Latency
Configure Streaming and Polling
Start Live Streaming
Record Streaming Data
FFT for Streaming
Configure File controller
Configure Control IDS
Custom Device Usage
Multi-xAF Library Support
Configure External Endpoints
Operations
Create a New Project
Create Signal Flow
Connecting a Device
Routing (Connections)
Device Synchronization
Launching Multiple Signal Flows
Tune a Signal Flow
Signal Flow Designer
Overview Of Signal Flow Designer
Components of Signal Flow Designer
Operations in Signal Flow Designer
Pin Labelling
View Audio Object Metadata
Column Name Configuration Panel
Upgrade Audio Object
Audio Object Processing State
Metering the Signal Flow
Copy and Paste Operation
Undo and Redo Operation
Block Control
Signal Flow Design Validation
Securing Audio Objects
Create a Signal Flow
Tune a Signal Flow
Native Panels
Launching Native Panel
Common Operation in Native Panel
Configuring Custom Native Panels
Additional Audio Parameters
Harman Audio Library Service
Multiple Framework Instances Support
Feedback loop in Signal Flow
Compound Audio Object
Create a Compound Audio Object
Import and Export CAO
Tuning and Editing CAO
Create Preset for CAO
Edit CAO Instance
Set password for CAO
Linking Custom Panel to CAO
Multi dll support for CAO
Delete a Compound Audio Object
Audio Object Description
Audio Object Description Overview
Audio Object General Information
Interface Objects
AudioIO
ControlIn
ControlOut
Basic Objects
Delay
Delay Panel
Gain
Gain Panel
Level Monitor
Level Monitor Panel
FaderBalance
Fader Balance Panel
Volume and Mute
Volume and Mute Panel
VolumeLite
Control Objects
Control Math
Control Grouper
Control GroupSplitter
Control Multi Adder
Control Mixer
Control Mixer Panel
Control Router
Control Router Panel
Control Smooth
AudioToControl
Lookup Table (LUT)
Lookup Table (LUT) Panel
Rate Control
Control Generator
Control Demux
Routing Objects
Router
Router Panel
Splitter
Demux
Selector
Source Objects
Noise Generator
Noise Generator Panel
Wave Generator
FilePlayer
Mixer Objects
Adder
Matrix Mixer
Matrix Mixer Panel
Merger
Fader Matrix
Fader Matrix Panel
Dynamic Object
Limiter
Limiter Panel
Filter Objects
Filter Objects General Information
ParameterBiquad
Parameter Biquad Panel
CoefficientBiquad
Coefficient Biquad Native Panel
Tone Control Extended
Tone Control Extended Panel
XoverBiquad
Xover Biquad Panel
FastConv
Fast Conv Panel
FIR Filter
FIR Filter Panel
Panel Designer
Panel Designer Overview
Panel Designer Components
Panel Designer Ribbon
Text Design
Fader Design
Rotary Design
Button Design
Box Design
LED Design
Meter Design
Other Design
Images
Advanced
Panels View
Custom Panel Properties View
Designer Workspace
Editor Windows
Parameter Address Editor
Multi-Parameter Address Editor
System Function Editor
State Indication Setup Window
Select Color Window
Discrete Values Editor
Indication Configuration Editor
LED Values Editor
Graph Parameters Window
Scale Editor
Create a Custom Panel in GTT
Switch between Multiple Parameter Sets
Parameter Set
Parameter Set Overview
Parameter Set Components
Apply Delta in Parameter Sets
Retrieve and Verify Parameter Sets
Importing and Exporting Set File
Preset Comparison
Create a Parameter Set in GTT
Real Time Analyzer
Real Time Analyzer Overview
Real Time Analyzer Components
Settings
Channels Settings
Generator Settings
Analyzer Settings
Microphone Calibration
RTA Advanced Settings
Sound Card Settings
Plugin Host Setting
Advanced Analyzer Settings
Advanced Generator Settings
Graph Display Settings
Mimo Convolver Settings
Recorder Settings
Routing Settings
Saving and Loading RTA File
Integrated Virtual Process Options
Probe Point Configuration
Real Time Data View
Graph Settings and Measurement
Traces
Trace Toolbar
Trace Configuration
Trace Functionalities
Offline Traces Anlaysis
RTA Shortcuts
Analysing Audio Signal
Measurement Module 2.0
Measurement Module Overview
Configurations
Device Output Mapping
Generator
Test Sound
Understand Measurement Process
Scene Setup
Speaker Configuration
Microphone Configuration
Define Measurement
Define Mannequin Measurement
Measurement Session
Performing Measurement
Central Viewer
Central Viewer Overview
Central Viewer Window
Configurations
Scene Mode
Chart Selector
Waterfall Chart
Graph Area
Curve Lists
Domain Selector
Import Export Central viewer settings
Starter Kit Utility Tool
Starter Kit Utility Tool (SKUtility) Overview
SKUtility Tool - Graphical Application
SKUtility Tool - Command-Line Interface
Useful Commands for Starter Kit
Starter Kit Troubleshooting
Global Tuning Tool
Suggest Edit
Captcha :
Submit
