Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
  • Getting Started
  • User Guides
  • Developer Guides
Table of Content
  • 20
Audio Object Developer Guide
  1. Purpose of this Document
  2. Overview
    1. Audio Object Workflow
    2. Audio Object Class
  3. Audio Object Configuration
    1. Design Time Configuration
      1. Metadata
    2. Advanced Design Time Configuration
      1. Audio Object Memory
  4. Basic Features and APIs
  5. Advanced Features and APIs
    1. Switch Processing State
    2. Debug and Monitoring
    3. Background Method
  6. Audio object Examples
    1. Example 1 - AwxAudioObjExt.cpp
    2. Example 2 - AwxAudioObjExtToolbox.cpp
    3. Example 3 - AwxAudioObjExtMemRecs.cpp
    4. Example 4 - AwxAudioObjExt.h
    5. Example 5 - AwxAudioObjExtToolbox.h
    6. Example 6 - AwxAudioObjExtMemRecs.h
  7. General Guidelines
  8. Adding External AO into AudioworX Package
  9. Building External Audio Object
Starter Kit Developer Guide
  1. Overview
  2. Setting Up the Developer Environment
  3. SKUtility Developer Options
  4. Build AWX External Object
  5. Running Debug Session
xAF Integration User Guide
  1. Support on xAF Integration
Troubleshooting
  1. GTT GUI Issues
  2. AmpSRV2
  3. Installation
6.Audio object Examples
  • Audio Object Developer Guide
  • Audio object Examples
A new audio object will implement the following functions depending on functionality. See the header files for the associated classes for detailed comments.
In the class which inherits CAudioObject – ie: CYourAudioObject.cpp
Abstract Methods (required implementation)
xUInt32 CAudioObject::getSize() const
Virtual Methods (optional implementation – depending on object features). This is not a complete list but contains the major virtual methods.
void      CAudioObject::init()
void      CAudioObject::calc(xFloat32** inputs, xFloat32** outputs)
void      CAudioObject::tuneXTP(xSInt32 subblock, xSInt32 startMemBytes, xSInt32 sizeBytes, xBool shouldAttemptRamp)
void      CAudioObject::controlSet(xSInt32 index, xFloat32 value)
xAF_Error CAudioObject::controlSet(xSInt32 index, xUInt32 sizeBytes, const void * const pValues)
void      CAudioObject::assignAdditionalConfig()
xInt8*    CAudioObject::getSubBlockPtr(xUInt16 subBlock)
xSInt32   CAudioObject::getSubBlockSize(xUInt16 subBlock)
In the class which inherits CAudioObjectToolbox – ie: CYourAudioObjectToolbox.cpp
const CAudioObjectToolbox::tObjectDescription*          CAudioObjectToolbox::getObjectDescription()
const CAudioObjectToolbox::tModeDescription*            CAudioObjectToolbox::getModeDescription(xUInt32 mode)
const CAudioObjectToolbox::additionalSfdVarDescription* CAudioObjectToolbox::getAdditionalSfdVarsDescription(xUInt32 index)
xAF_Error                                               CAudioObjectToolbox::getObjectIo(ioObjectConfigOutput* configOut)
xUInt32                                                 CAudioObjectToolbox::getXmlSVTemplate(tTuningInfo* info, xInt8* buffer, xUInt32 maxLen)
xUInt32                                                 CAudioObjectToolbox::getXmlObjectTemplate(tTuningInfo* info, xInt8* buffer, xUInt32 maxLen)
xUInt32                                                 CAudioObjectToolbox::getXmlFileInfo(tTuningInfo* info, xInt8* buffer, xUInt32 maxLen)
void                                                    CAudioObjectToolbox::createStaticMetadata()
void                                                    CAudioObjectToolbox::createDynamicMetadata(ioObjectConfigInput& configIn, ioObjectConfigOutput& configOut)
In the class which inherits CMemoryRecordProperties – ie: CYourAudioObjectMemRecs.cpp
xUInt8 CMemoryRecordProperties::getMemRecords(xAF_memRec* memTable, xAF_memRec& scratchRecord, xInt8 target, xInt8 format)
Source code for AwxAudioObjExt audio object can be found in HarmanAudioworX installation folder. The path for the source code is
Program FilesHarmanHarmanAudioworXext-reference-algorithmsexternalinc
Program FilesHarmanHarmanAudioworXext-reference-algorithmsexternalsrc
The code snippet for source and include files is provided in following sections for reference
« Background MethodExample 1 - AwxAudioObjExt.cpp »
Suggest Edit
  • Careers
  • Contact
