Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
  • Getting Started
  • User Guides
  • Developer Guides
Table of Content
  • 20
Audio Object Developer Guide
  1. Purpose of this Document
  2. Overview
    1. Audio Object Workflow
    2. Audio Object Class
  3. Audio Object Configuration
    1. Design Time Configuration
      1. Metadata
    2. Advanced Design Time Configuration
      1. Audio Object Memory
  4. Basic Features and APIs
  5. Advanced Features and APIs
    1. Switch Processing State
    2. Debug and Monitoring
    3. Background Method
  6. Audio object Examples
    1. Example 1 - AwxAudioObjExt.cpp
    2. Example 2 - AwxAudioObjExtToolbox.cpp
    3. Example 3 - AwxAudioObjExtMemRecs.cpp
    4. Example 4 - AwxAudioObjExt.h
    5. Example 5 - AwxAudioObjExtToolbox.h
    6. Example 6 - AwxAudioObjExtMemRecs.h
  7. General Guidelines
  8. Adding External AO into AudioworX Package
  9. Building External Audio Object
Starter Kit Developer Guide
  1. Overview
  2. Setting Up the Developer Environment
  3. SKUtility Developer Options
  4. Build AWX External Object
  5. Running Debug Session
xAF Integration User Guide
  1. Support on xAF Integration
Troubleshooting
  1. GTT GUI Issues
  2. AmpSRV2
  3. Installation
6.2.Example 2 - AwxAudioObjExtToolbox.cpp
  • Audio Object Developer Guide
  • Example 2 - AwxAudioObjExtToolbox.cpp
*   file      AwxAudioObjExtToolbox.cpp
*   brief     AwxAudioObjExt Toolbox Source file
*   details   Implements the AwxAudioObjExt signal design API
*   details   Project    Extendable Audio Framework
*   copyright Harman/Becker Automotive Systems GmbH
       2020
       All rights reserved
*   author    xAF Team
*   xaf mandataory includes to handle the toolbox related data
#include "AwxAudioObjExtToolbox.h"
#include "XafXmlHelper.h"
#include "AudioObjectProperties.h"
#include "AwxAudioObjExt.h"
#include "XafMacros.h"
#include "AudioObject.h"
// the revision number may be different for specific targets
#define MIN_REQUIRED_XAF_VERSION            (RELEASE_U)
// mode specific defines
#define AUDIO_IN_OUT_MIN                    (1)
#define AUDIO_IN_OUT_MAX                    (255)
#define EST_MEMORY_CONSUMPTION_NA           (0)         // memory consuption not available/measured
#define EST_CPU_LOAD_CONSUMPTION_NA         (0.f) // cpu load not available/measured
#define CONTROL_GAIN_MAX                   (30.0f)
#define CONTROL_GAIN_MIN                   (-128.0f)
#define CONTROL_GAIN_IN_LABEL              "Gain"
#define MAX_CONFIG_MIN_GAIN_dB              (-12.0f)
#define MAX_CONFIG_MAX_GAIN_dB              (30.0f)
#define MAX_GAIN_DEFAULT_GAIN_dB            (10.0f)
CAwxAudioObjExtToolbox::CAwxAudioObjExtToolbox()
CAwxAudioObjExtToolbox::~CAwxAudioObjExtToolbox()
static CAudioObjectToolbox::additionalSfdVarDescription theVar;
const CAwxAudioObjExtToolbox::additionalSfdVarDescription* CAwxAudioObjExtToolbox::getAdditionalSfdVarsDescription(xUInt32 index)
    CAudioObjectToolbox::additionalSfdVarDescription* ptr = &theVar;
    static CAudioObjectToolbox::MinMaxDefault addVar1 = { MAX_CONFIG_MIN_GAIN_dB ,MAX_CONFIG_MAX_GAIN_dB ,MAX_GAIN_DEFAULT_GAIN_dB }; //Min,max,default values for additional config variable
    static CAudioObjectToolbox::MinMaxDefault addVar2 = { 0, 1, 0 }; //Min,max,default values
    static CAudioObjectToolbox::addVarsSize m_AddtionalVarSize1[NUM_DIMENSION_VAR] =
        // size, label, start index, increment
        {1, "Max Gain per channel(dB)", 0, 1}
    static CAudioObjectToolbox::addVarsSize m_AddtionalVarSize2[NUM_DIMENSION_VAR] =
        {1, "Disable: 0nEnable  : 1", 0, 1}
     if (index == 0)
       theVar.mP_Label = "Max Gain per channel";
       theVar.m_DataType = xAF_FLOAT_32;
       theVar.mP_RangeSet = &addVar1;
       theVar.m_Dimension = 1;
       theVar.m_DataOrder = xAF_NONE;
       //size varies according to the number of channels
       m_AddtionalVarSize1[0].m_Size = static_cast(m_NumAudioIn);
       theVar.mP_MaddVarsSize = m_AddtionalVarSize1;
     else if (index == 1)
         theVar.mP_Label = "Abstracted Tuning Memory";
         theVar.m_DataType = xAF_UCHAR;
         theVar.mP_RangeSet = &addVar2;
         theVar.mP_MaddVarsSize = m_AddtionalVarSize2;
     else
         /* Invalid index. Return NULL */
         ptr = NULL;
     return ptr;
const CAudioObjectToolbox::tObjectDescription* CAwxAudioObjExtToolbox::getObjectDescription()
    static const CAudioObjectToolbox::tObjectDescription descriptions =
        1, 1, 0, 0, "AwxAudioObjExt", "Simple Object to start with for 3rd party/external objects integration", "External", AWX_EXT_NUM_ADD_VARS, AWX_EXT_NUM_MODES
    return &descriptions;
const CAudioObjectToolbox::tModeDescription* CAwxAudioObjExtToolbox::getModeDescription(xUInt32 mode)
    static const CAudioObjectToolbox::tModeDescription modeDescription[AWX_EXT_NUM_MODES] =
        {"Gain", "No control input", 0, 0, "", CFG_NCHANNEL},
        {"GainWithControl", "One gain control input pin gets added", 0, 0, "", CFG_NCHANNEL},
    return (mode < (sizeof(modeDescription) / sizeof(tModeDescription))) ? &modeDescription[mode] : static_cast<tModeDescription*>(NULL);
xAF_Error CAwxAudioObjExtToolbox::getObjectIo(ioObjectConfigOutput* configOut)
    if (static_cast(GAIN_WITH_CONTROL) == m_Mode)
        configOut->numControlIn = 1;
        configOut->numControlOut = 0;
    else
        configOut->numControlIn = 0;
    return xAF_SUCCESS;
xUInt32 CAwxAudioObjExtToolbox::getXmlObjectTemplate(tTuningInfo* info, xInt8* buffer, xUInt32 maxLen)
    initiateNewBufferWrite(buffer, maxLen);
    // add your tuning parameters here in order to show up in the tuning tool
    // the number of params specified here, depends on the number to be tuned in GTT
    // in this example we are exposing the tuning parameters as arrays split into 2 subblocks
    //template 1
    xSInt32 numAudioIn = static_cast(m_NumAudioIn);
    xSInt32 blockID = info->Global_Object_Count; // uniq to this instance
    xUInt32 id = 0;
    for (xSInt32 i = 0; i < numAudioIn; i++) { //Max value for each channel to show up shall be specified by this function xFloat32 gainval = getMaxGain(i); xAFOpenLongXMLTag("Object"); string templateName = string("").append("AwxAudioObjExtTuneTemplate").append(xAFIntToString(i + 1)).append(xAFIntToString(blockID)); xAFAddFieldToXMLTag("Key", templateName.c_str()); xAFEndLongXMLTag(); xAFWriteQuickXmlTag("ExplorerIcon", "Object"); xAFWriteXmlTag("StateVariables", XML_OPEN); xAFWriteStateVariable("Gain", // name id, // id NULL, // control law "dB", // unit type DataTypes[xAF_FLOAT], // data type -128.0, // min gainval, // max 0.0, // default 0u, // offset NULL, // encode value NULL, // decode value DataTypeConverters[xAF_FLOAT], // bit converter false // disable streaming ); id++; xAFWriteStateVariable("Mute", // name id, // id NULL, // control law NULL, // unit type DataTypes[xAF_UINT], // data type 0.0, // min 1.0, // max 0.0, // default 4u, // offset NULL, // encode value NULL, // decode value DataTypeConverters[xAF_UINT], // bit converter false // disable streaming ); id++; xAFWriteXmlTag("StateVariables", XML_CLOSE); xAFWriteXmlTag("Object", XML_CLOSE); } //template 2 //It shall be shown up in the State Variable Explorer if through additional configuration "Abstracted Tuning Memory" is set to 1 or enabled. if (static_cast(ENABLE_BLOCK) == m_EnMemory) { xAFOpenLongXMLTag("Object"); xAFAddFieldToXMLTag("Key", "AwxAudioObjExtArrayTemplate"); xAFEndLongXMLTag(); xAFWriteQuickXmlTag("ExplorerIcon", "Object"); xAFWriteXmlTag("StateVariables", XML_OPEN); xAFWriteStateVariableBuffer(/* name = */ "FloatArray", /* id = */ id, /* type = */ FLOATARRAY_SV, /* size = */ FLOAT_ARRAY_SIZE, /* streamIdx = */ id, /* minVal = */ -1000.0, /* maxVal = */ 1000.0, /* defaultVal = */ 0.0, /* offset = */ 0, /* isStreamable = */ false); xAFWriteXmlTag("StateVariables", XML_CLOSE); xAFWriteXmlTag("Object", XML_CLOSE); } return finishWritingToBuffer(); } xUInt32 CAwxAudioObjExtToolbox::getXmlFileInfo(tTuningInfo* info, xInt8* buffer, xUInt32 maxLen) { initiateNewBufferWrite(buffer, maxLen); xUInt32 hiqnetInc = 0u; xUInt8 subBlock = 0u; xSInt32 blockID = info->Global_Object_Count; // uniq to this instance
    xAFWriteObject(info->Name, static_cast(info->Global_Object_Count), hiqnetInc, static_cast(info->HiQNetVal), 0);
    xAFWriteXmlTag("Objects", XML_OPEN);
    xSInt32 numAudioIn = static_cast(m_NumAudioIn); // m_NumAudioIn == m_NumAudioOut
    xAFWriteXmlObjectContainer("Gains", hiqnetInc, subBlock, PARAM_CATEGORY);
    for(xSInt32 i = 0; i < numAudioIn; i++) { string templateName = string("").append("AwxAudioObjExtTuneTemplate").append(xAFIntToString(i+1)).append(xAFIntToString(blockID)); xAFWriteXmlObjectTemplateInstance(templateName.c_str(), string("Ch").append(xAFIntToString(i+1)).c_str(), i * 8, 1 + i); // 8 is related here to the internal memory layout where a "state/tuning" is related to a block of N-bytes and withing this needs to be offset hiqnetInc++; } xAFWriteXmlTag("Objects", XML_CLOSE); xAFWriteXmlTag("Object", XML_CLOSE); //gains if (static_cast(ENABLE_BLOCK) == m_EnMemory) { xAFWriteXmlObjectBlockOffset("AwxAudioObjExtArrayTemplate", "FloatArrayMemory", subBlock, static_cast(info->HiQNetVal), hiqnetInc, PARAM_CATEGORY);
        hiqnetInc++;
void CAwxAudioObjExtToolbox::createStaticMetadata()
    m_StaticMetadata.minReqXafVersion = static_cast(MIN_REQUIRED_XAF_VERSION);
    setAudioObjectVersion(AWXAUDIOOBJEXT_VERSION_MAJOR, AWXAUDIOOBJEXT_VERSION_MINOR, AWXAUDIOOBJEXT_VERSION_REVISION);
    setTuningVersion     (AWXAUDIOOBJEXT_TUNING_VERSION_MAJOR, AWXAUDIOOBJEXT_TUNING_VERSION_MINOR);
    m_StaticMetadata.supDataFormats.push_back(xAF_DATATYPE_FLOAT);
    //creation/release date
    setCreationDate(2022, 8, 4);
    //Simple AO supports in-place computation
    m_StaticMetadata.inPlaceComputationEnabled = true;
    //This flag allows to set whether the object dynamically updates its additional vars based on input params
    m_StaticMetadata.isAddVarUpdateRequired = true;
void CAwxAudioObjExtToolbox::createDynamicMetadata(ioObjectConfigInput& configIn, ioObjectConfigOutput& configOut)
    metaDataControlDescription ctrlDesc;
    // define audio in metadata
    m_DynamicMetadata.audioIn.Min = AUDIO_IN_OUT_MIN;
    m_DynamicMetadata.audioIn.Max = AUDIO_IN_OUT_MAX;
    // define audio out metadata
    m_DynamicMetadata.audioOut.Min = AUDIO_IN_OUT_MIN;
    m_DynamicMetadata.audioOut.Max = AUDIO_IN_OUT_MAX;
    switch (configIn.mode)
        case static_cast(GAIN_WITH_CONTROL) :
        // define control in min, max and label values for the control pin
        ctrlDesc.Min = CONTROL_GAIN_MIN;
        ctrlDesc.Max = CONTROL_GAIN_MAX;
        ctrlDesc.Label = CONTROL_GAIN_IN_LABEL;
        m_DynamicMetadata.controlIn.push_back(ctrlDesc);
        break;
        default:
        break;
    m_DynamicMetadata.estMemory = EST_MEMORY_CONSUMPTION_NA;
    m_DynamicMetadata.estMIPS = EST_CPU_LOAD_CONSUMPTION_NA;
« Example 1 - AwxAudioObjExt.cppExample 3 - AwxAudioObjExtMemRecs.cpp »
Suggest Edit
  • Careers
  • Contact
