Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
  • Getting Started
  • User Guides
  • Developer Guides
Table of Content
  • 20
Audio Object Developer Guide
  1. Purpose of this Document
  2. Overview
    1. Audio Object Workflow
    2. Audio Object Class
  3. Audio Object Configuration
    1. Design Time Configuration
      1. Metadata
    2. Advanced Design Time Configuration
      1. Audio Object Memory
  4. Basic Features and APIs
  5. Advanced Features and APIs
    1. Switch Processing State
    2. Debug and Monitoring
    3. Background Method
  6. Audio object Examples
    1. Example 1 - AwxAudioObjExt.cpp
    2. Example 2 - AwxAudioObjExtToolbox.cpp
    3. Example 3 - AwxAudioObjExtMemRecs.cpp
    4. Example 4 - AwxAudioObjExt.h
    5. Example 5 - AwxAudioObjExtToolbox.h
    6. Example 6 - AwxAudioObjExtMemRecs.h
  7. General Guidelines
  8. Adding External AO into AudioworX Package
  9. Building External Audio Object
Starter Kit Developer Guide
  1. Overview
  2. Setting Up the Developer Environment
  3. SKUtility Developer Options
  4. Build AWX External Object
  5. Running Debug Session
xAF Integration User Guide
  1. Support on xAF Integration
Troubleshooting
  1. GTT GUI Issues
  2. AmpSRV2
  3. Installation
6.3.Example 3 - AwxAudioObjExtMemRecs.cpp
  • Audio Object Developer Guide
  • Example 3 - AwxAudioObjExtMemRecs.cpp
*   file      AwxiAudioObjExtMemRecs.cpp
*   brief     Memory related description Source file
*   details   Implements the audio object memory related API
*   details   Project    Extendable Audio Framework
*   copyright Harman/Becker Automotive Systems GmbH
       2020
       All rights reserved
*   author    xAF Team
*   include files required to request the dynamic memory
#include "AwxAudioObjExtMemRecs.h"
xUInt8 CAwxAudioObjExtMemRecs::getMemRecords(xAF_memRec* memTable, xAF_memRec& scratchRecord, xInt8 target, xInt8 format)
	xUInt8 numMemRecords = (static_cast(ENABLE_BLOCK) == m_EnMemory) ? static_cast(NUM_MEM_RECORDS) : static_cast(FLOATARRAY);
	//m_Param memory
    memTable[PARAM].alignment = 4;
    memTable[PARAM].size = static_cast(static_cast(m_NumAudioIn) * NUM_PARAMS_PER_CHANNEL * sizeof(xFloat32));
	memTable[PARAM].label = "Tuning Parameters";
	//m_Coeff memory
    memTable[COEFF].size = static_cast(static_cast(m_NumAudioIn) * sizeof(xFloat32));
	memTable[COEFF].alignment = 4;
	memTable[COEFF].label = "Gain Values";
	//m_MemBlck memory(Abstracted Tuning Memory)
	if (static_cast(ENABLE_BLOCK) == m_EnMemory)
		memTable[FLOATARRAY].size = FLOAT_ARRAY_SIZE * sizeof(xFloat32);
		memTable[FLOATARRAY].alignment = 4;
		memTable[FLOATARRAY].label = "Abstracted Tuning Memory values";
    return numMemRecords;
« Example 2 - AwxAudioObjExtToolbox.cppExample 4 - AwxAudioObjExt.h »
Suggest Edit
  • Careers
  • Contact
