Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
  • Getting Started
  • User Guides
  • Developer Guides
Table of Content
Global Tuning Tool
  1. About Global Tuning Tool
    1. System Requirements
  2. Workspace Overview
    1. Home Screen
      1. Home screen Options
      2. Application Options
    2. Device Designer Overview
      1. Tools
      2. Connection
      3. Import and Export
      4. Tuning
      5. Device Panels
    3. Devices and Template View
    4. About Core Objects Toolbox
    5. Device Operations
    6. Properties Panel
    7. Device View
    8. Help
  3. Configurations
    1. Configure State Variable
      2. Core Object Settings
      3. Custom Actions Settings
      5. Maintain Folder Structure
      7. Handling Dual Responses
      8. Send Preset Data Online
    4. Link Window
    5. Configure Controller
    6. Launch MIPS Profiling
    7. Launch Memory Profiling
    8. Editing Memory Latency
      1. Start Live Streaming
      2. Record Streaming Data
      3. FFT for Streaming
    10. Configure File controller
    11. Configure Control IDS
    12. Custom Device Usage
    13. Multi-xAF Library Support
  4. Operations
    1. Create a New Project
    2. Create Signal Flow
    3. Connecting a Device
    4. Routing (Connections)
    5. Device Synchronization
    7. Tune a Signal Flow
  5. Designing Custom Panel
    1. Panel Designer Ribbon
      1. Text Design
      2. Fader Design
      3. Rotary Design
      4. Button Design
      5. Box Design
      6. LED Design
      7. Meter Design
      8. Other Design
      9. Images
      10. Advanced
    2. Panels View
    4. Designer Workspace
    5. Editor Windows
      1. Parameter Address Editor
      3. System Function Editor
      5. Select Color Window
      6. Discrete Values Editor
      8. LED Values Editor
      9. Graph Parameters Window
      10. Scale Editor
  6. Working with Parameter Set
    1. Parameter Set Overview
      1. Configuring Parameter Data
      4. Import and Export Set File
      5. Preset Comparison
      9. Search in Parameter Sets
Signal Flow Designer
    1. Pin Labelling
    2. View Audio Object Metadata
    4. Upgrade Audio Object
    6. Metering the Signal Flow
    7. Copy and Paste Operation
    8. Undo and Redo Operation
    9. Block Control
    11. Securing Audio Objects
  4. Create a Signal Flow
  5. Tune a Signal Flow
  6. Native Panels
    1. Launching Native Panel
  11. Compound Audio Object
    2. Import and Export CAO
    3. Tuning and Editing CAO
    4. Create Preset for CAO
    5. Edit CAO Instance
    6. Set password for CAO
    8. Multi dll support for CAO
Audio Object Description
  2. Interface Objects
    1. AudioIO
    2. ControlIn
    3. ControlOut
  3. Basic Objects
    1. Delay
      1. Delay Panel
    2. Gain
      1. Gain Panel
    3. Level Monitor
      1. Level Monitor Panel
    4. Fader Balance
      1. Fader Balance Panel
    5. Volume and Mute
      1. Volume and Mute Panel
    6. VolumeLite
  4. Control Objects
    1. Control Math
    2. Control Grouper
    3. Control GroupSplitter
    4. Control Multi Adder
    5. Control Mixer
      1. Control Mixer panel
    6. Control Router
      1. Control Router panel
    7. Control Smooth
    8. AudioToControl
    9. Lookup Table (LUT)
      1. Lookup Table (LUT) Panel
    10. Control Generator
  5. Routing Objects
    1. Router
      1. Router Panel
    2. Demux
    3. Selector
  6. Source Objects
    1. Noise Generator
      1. Noise Generator Panel
    2. Wave Generator
    3. FilePlayer
  7. Mixer Objects
    1. Adder
    2. Matrix Mixer
      1. Matrix Mixer Panel
    3. Merger
    4. Fader Matrix
  8. Dynamic Object
    1. Limiter
      1. Limiter Panel
  9. Filter Objects
    1. ParameterBiquad
      1. Parameter Biquad Panel
    2. CoefficientBiquad
    3. Tone Control Extended
    4. XoverBiquad
      1. Xover Biquad Panel
    5. FastConv
      1. Fast Conv Panel
    6. FIR Filter
      1. FIR Filter Panel
Real Time Analyzer
  3. Settings
    1. Channels Settings
    2. Generator Settings
    3. Analyzer Settings
    4. Microphone Calibration
    5. RTA Advanced Settings
      1. Sound Card Settings
      2. Plugin Host Setting
      3. Advance Analyzer Settings
      4. Advance Generator Settings
      5. Graph Display Settings
      6. MIMO Convolver Settings
      7. Recorder Settings
      8. Routing Settings
  5. Probe Point Configuration
  6. Real Time Data View
  8. Traces
    1. Trace Toolbar
    2. Trace Configuration
    3. Trace Functionalities
    4. RTA Shortcuts
  9. Analysing Audio Signal
Measurement Module 2.0
  2. Configurations
    1. Device Output Mapping
    2. Generator
    3. Test Sound
    1. Scene Setup
    2. Speaker Configuration
    3. Microphone Configuration
    4. Define Measurement
    5. Measurement Session
Central Viewer
  1. Central Viewer Overview
  2. Central Viewer Window
    1. Configurations
    2. Scene Mode
    3. Chart Selector
    4. Waterfall Chart
    5. Graph Area
    6. Curve Lists
    7. Domain Selector
Starter Kit Utility Tool
  1. Starter Kit Utility Tool
2.1.2.Application Options
  • Global Tuning Tool
  • Application Options
The option menu allows you to configure various settings in GTT, such as the general settings, project settings, custom panel grid settings, and event log settings.
General Settings
In the general settings dialogue box, you have the option to customize measurement settings, venue menu settings, explorer settings, and system conversion settings.
Measurement Settings Measurement Session Raw Data Folder: Specify a desired location where you would like to store the raw data for the measurement session.
Predefined Stimulus Signals Folder: Specify a desired location where you would like to store the predefined stimulus signals.
Venu View Settings  – Show Warnings: If enabled, all device alerts will be displayed in the venue.
 – Show Incompatible HiQnet App Warning: If enabled, a warning dialog will appear upon startup if another HiQnet application is already running.
 – Load Previous File On Startup:
  • If checked the venue file that was last used or saved will be automatically loaded upon startup.
  • If unchecked the venue file needs to be loaded manually (default)
Explorer Settings If enabled a drop-down arrow appears next to discovered devices in the venue explorer. When the arrow is clicked, the complete device information is displayed.
Address Settings  – Display Addresses in Hex.
  • If checked, the displays device and object addresses in hexadecimal.
  • If unchecked, the displays the device and object addresses in decimal.
 – Display Object Addresses as Octals.
  • If checked, the displays the object addresses in three period-separated values.
  • If unchecked, the displays object addresses as a single value.
System Conversions This option makes all instances of parametric EQ displayed either as bandwidth in Octaves or as bandwidth as Q at the user’s discretion. Switching from one option to the other will be on a global basis for the entire application.
Advanced  – Increase Window Handle Limit to Maximum: This option allows you to set the handle limit to it s maximum value (checking the checkbox), this will increase the maximum number of controls/planes allowed by the operating system. By default, this option is unchecked.
If GTT exhausts its handle resources and is unable to launch a panel, it will notify you of the issue and prompt you to close any unused panels in order to free up resources.
 – Select wiring controls in real-time when using lasso selecting: When using the lasso to select objects, having this box checked allows the selection of wiring contThis option makes all instances of parametric EQ displayed either as bandwidth in Octaves or as bandwidth as Q at the user’s discretion. Switching from one option to the other will be on a global basis for the entire application.rols.
 – Error Reporting: This option enables GTT to send important error information automatically to Harman.
On the Harman Crash Reporting Disclaimer dialogue box, check the “Send important error information automatically to Harman” option. This feature will send application and computer information to the Harman GTT team in the event of an application crash.
Uncheck the checkbox if you do not want any information sent.
Project Settings
Project In the project settings, you have the option to designate a folder where you would like to store the project file. If you want to exclude Measurement Session data from the project export, uncheck the “Include Measurement Sessions in Project Export” options.
Decimal Separator for Exported files You can select between a dot or comma to specify the separator of any quantity for the files you export in GTT.
Currently, this option is only supported for traces exported in .txt and .txtrclist in the RTA module.
Make sure to configure the project settings prior to initiating the export process.
Custom Panel Designer Settings
In GTT, you can modify the settings for the custom control panel design view, such as the grid, snap lines, and control transparency configuration.
However, it is important to note that once you make changes to these settings, you must close any open custom control panel designer and reopen it for the changes to take effect.
Grid Layout The design grid allows you to arrange controls relative to specific marks on the design view of the Custom Panel.
  • Show Grid: If checked, it will display the design grid. This feature is overridden with the “Snap Lines” feature below.
  • Snap to Grid: If checked, it will snap design objects to the design grid (if selected).
  • Grid Size: It is the distance between grid lines (in pixels); x = horizontal, y = vertical
Advanced Enable Control Transparency
Control transparency gives the controls on Custom Panels transparent backgrounds. While this option makes the control panel designer more attractive, it may slow the computer system performance significantly to process all the graphics.
If you are having problems with the graphics building too slowly on the screen, uncheck the box “Enable Control Transparency.”
While they will show up as overlapped on the Custom Panel designer, they will show up as transparent on the Custom Panel if the background is transparent (defined in Control Properties).
User Interface Settings
Font Size Choose the desired font size:
  • Small (12 points): Select this if you prefer a smaller font. This is the default setting.
  • Medium (16 points): This size is suitable for a moderate, more comfortable reading experience.
  • Large (20 points): Choose this if you prefer a larger, more readable font.
Currently, font size change will impact only in the Central Viewer Browsing and Permanent curve name font sizes.
Windows Setting – Show all sub-windows on top:
Check this option to ensure all sub-windows are always visible above the main window.
Tuning Data Settings
Retain Tuning Data By default, tuning data of the Audio object will be lost when the Mode, Additional Parameter, or Number of Elements property changes in the signal flow.
To retain tuning data in the above cases, please check the appropriate option based on your needs.
Event Log Settings
Event Log View
  • Clear Log at Startup: Enabling this option will result in the event log being automatically cleared every time GTT is started up.
  • Maximum number of events in view: Sets the maximum number of events shown in the event log window.
  • View Update Rate: You can configure the update rate to be either instantaneous or delayed.
  • View Archive: Brings up the “Event Log Archive” dialogue box.
The Event Log window tab shows events that have occurred on HiQnet devices. The log may be utilized by individual devices to perform certain operations. You can also use the logs for troubleshooting.
The Event Log Indicator will notify you in real-time as events occur.
You can also group information by heading. Click and hold on the heading and drag it to the top just below the log file to the “Group(s)” option. The screen will now display by the heading you selected.
To remove the grouping, click and hold on the heading and drag it off the “Group(s)” option.
The Event Log Archive is a store of the Event Log from when the application was opened.
Miscellaneous
  • Disable Logging: Turns off the Event Log.
  • Capture BSS Logfiles: Include the Log Files that have been saved in BSS devices into the Audio.
  • Customize Warnings: This window allows you to set the minimum warning priority level, which warning types you want to receive a warning from and which category you want to receive warnings from.
« Home screen OptionsDevice Designer Overview »
Suggest Edit
  • Careers
  • Contact
