Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
  • Getting Started
  • User Guides
  • Developer Guides
Table of Content
Global Tuning Tool
  1. About Global Tuning Tool
    1. System Requirements
  2. Workspace Overview
    1. Home Screen
      1. Home screen Options
      2. Application Options
    2. Device Designer Overview
      1. Tools
      2. Connection
      3. Import and Export
      4. Tuning
      5. Device Panels
    3. Devices and Template View
    4. About Core Objects Toolbox
    5. Device Operations
    6. Properties Panel
    7. Device View
    8. Help
  3. Configurations
    1. Configure State Variable
      2. Core Object Settings
      3. Custom Actions Settings
      5. Maintain Folder Structure
      7. Handling Dual Responses
      8. Send Preset Data Online
    4. Link Window
    5. Configure Controller
    6. Launch MIPS Profiling
    7. Launch Memory Profiling
    8. Editing Memory Latency
      1. Start Live Streaming
      2. Record Streaming Data
      3. FFT for Streaming
    10. Configure File controller
    11. Configure Control IDS
    12. Custom Device Usage
    13. Multi-xAF Library Support
  4. Operations
    1. Create a New Project
    2. Create Signal Flow
    3. Connecting a Device
    4. Routing (Connections)
    5. Device Synchronization
    7. Tune a Signal Flow
  5. Designing Custom Panel
    1. Panel Designer Ribbon
      1. Text Design
      2. Fader Design
      3. Rotary Design
      4. Button Design
      5. Box Design
      6. LED Design
      7. Meter Design
      8. Other Design
      9. Images
      10. Advanced
    2. Panels View
    4. Designer Workspace
    5. Editor Windows
      1. Parameter Address Editor
      3. System Function Editor
      5. Select Color Window
      6. Discrete Values Editor
      8. LED Values Editor
      9. Graph Parameters Window
      10. Scale Editor
  6. Working with Parameter Set
    1. Parameter Set Overview
      1. Configuring Parameter Data
      4. Import and Export Set File
      5. Preset Comparison
      9. Search in Parameter Sets
Signal Flow Designer
    1. Pin Labelling
    2. View Audio Object Metadata
    4. Upgrade Audio Object
    6. Metering the Signal Flow
    7. Copy and Paste Operation
    8. Undo and Redo Operation
    9. Block Control
    11. Securing Audio Objects
  4. Create a Signal Flow
  5. Tune a Signal Flow
  6. Native Panels
    1. Launching Native Panel
  11. Compound Audio Object
    2. Import and Export CAO
    3. Tuning and Editing CAO
    4. Create Preset for CAO
    5. Edit CAO Instance
    6. Set password for CAO
    8. Multi dll support for CAO
Audio Object Description
  2. Interface Objects
    1. AudioIO
    2. ControlIn
    3. ControlOut
  3. Basic Objects
    1. Delay
      1. Delay Panel
    2. Gain
      1. Gain Panel
    3. Level Monitor
      1. Level Monitor Panel
    4. Fader Balance
      1. Fader Balance Panel
    5. Volume and Mute
      1. Volume and Mute Panel
    6. VolumeLite
  4. Control Objects
    1. Control Math
    2. Control Grouper
    3. Control GroupSplitter
    4. Control Multi Adder
    5. Control Mixer
      1. Control Mixer panel
    6. Control Router
      1. Control Router panel
    7. Control Smooth
    8. AudioToControl
    9. Lookup Table (LUT)
      1. Lookup Table (LUT) Panel
    10. Control Generator
  5. Routing Objects
    1. Router
      1. Router Panel
    2. Demux
    3. Selector
  6. Source Objects
    1. Noise Generator
      1. Noise Generator Panel
    2. Wave Generator
    3. FilePlayer
  7. Mixer Objects
    1. Adder
    2. Matrix Mixer
      1. Matrix Mixer Panel
    3. Merger
    4. Fader Matrix
  8. Dynamic Object
    1. Limiter
      1. Limiter Panel
  9. Filter Objects
    1. ParameterBiquad
      1. Parameter Biquad Panel
    2. CoefficientBiquad
    3. Tone Control Extended
    4. XoverBiquad
      1. Xover Biquad Panel
    5. FastConv
      1. Fast Conv Panel
    6. FIR Filter
      1. FIR Filter Panel
Real Time Analyzer
  3. Settings
    1. Channels Settings
    2. Generator Settings
    3. Analyzer Settings
    4. Microphone Calibration
    5. RTA Advanced Settings
      1. Sound Card Settings
      2. Plugin Host Setting
      3. Advance Analyzer Settings
      4. Advance Generator Settings
      5. Graph Display Settings
      6. MIMO Convolver Settings
      7. Recorder Settings
      8. Routing Settings
  5. Probe Point Configuration
  6. Real Time Data View
  8. Traces
    1. Trace Toolbar
    2. Trace Configuration
    3. Trace Functionalities
    4. RTA Shortcuts
  9. Analysing Audio Signal
Measurement Module 2.0
  2. Configurations
    1. Device Output Mapping
    2. Generator
    3. Test Sound
    1. Scene Setup
    2. Speaker Configuration
    3. Microphone Configuration
    4. Define Measurement
    5. Measurement Session
Central Viewer
  1. Central Viewer Overview
  2. Central Viewer Window
    1. Configurations
    2. Scene Mode
    3. Chart Selector
    4. Waterfall Chart
    5. Graph Area
    6. Curve Lists
    7. Domain Selector
Starter Kit Utility Tool
  1. Starter Kit Utility Tool
6.1.2.Apply Delta in Parameter Sets
  • Global Tuning Tool
  • Apply Delta in Parameter Sets
You can send the tuning values to the device using “Apply Delta” or “Apply” function.
  • Apply Delta function: Only sends the tuning values which updated in the selected set.
  • Apply function: Sends all the tuning values of the selected set.
To Apply Delta in Parameter Sets:
  1. Open the Signal Flow Designer and create a signal flow.
  2. Double-click on the Gain audio object to open the native panel. The native panel displays gain values. Now keep the Parameter Sets window and Gain window side-by-side.
    Make sure to drag and drop the Gain AO from the Explorer tree to the Parameter set group workspace before you start comparing. You will see the gain values as set in Parameter Sets with respect to the Gain native panel.
  3. On the Parameter set group workspace, change the values in the parameter set and click Apply Delta. You will see the native panel updated with respect to the parameter set value.
Similarly, if you click on Apply, all the tuning values of the selected set will be send.
« Configuring Parameter DataRetrieve and Verify Parameter »
Suggest Edit
  • Careers
  • Contact
