Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
  • Getting Started
  • User Guides
  • Developer Guides
Table of Content
Global Tuning Tool
  1. About Global Tuning Tool
    1. System Requirements
  2. Workspace Overview
    1. Home Screen
      1. Home screen Options
      2. Application Options
    2. Device Designer Overview
      1. Tools
      2. Connection
      3. Import and Export
      4. Tuning
      5. Device Panels
    3. Devices and Template View
    4. About Core Objects Toolbox
    5. Device Operations
    6. Properties Panel
    7. Device View
    8. Help
  3. Configurations
    1. Configure State Variable
      2. Core Object Settings
      3. Custom Actions Settings
      5. Maintain Folder Structure
      7. Handling Dual Responses
      8. Send Preset Data Online
    4. Link Window
    5. Configure Controller
    6. Launch MIPS Profiling
    7. Launch Memory Profiling
    8. Editing Memory Latency
      1. Start Live Streaming
      2. Record Streaming Data
      3. FFT for Streaming
    10. Configure File controller
    11. Configure Control IDS
    12. Custom Device Usage
    13. Multi-xAF Library Support
  4. Operations
    1. Create a New Project
    2. Create Signal Flow
    3. Connecting a Device
    4. Routing (Connections)
    5. Device Synchronization
    7. Tune a Signal Flow
  5. Designing Custom Panel
    1. Panel Designer Ribbon
      1. Text Design
      2. Fader Design
      3. Rotary Design
      4. Button Design
      5. Box Design
      6. LED Design
      7. Meter Design
      8. Other Design
      9. Images
      10. Advanced
    2. Panels View
    4. Designer Workspace
    5. Editor Windows
      1. Parameter Address Editor
      3. System Function Editor
      5. Select Color Window
      6. Discrete Values Editor
      8. LED Values Editor
      9. Graph Parameters Window
      10. Scale Editor
  6. Working with Parameter Set
    1. Parameter Set Overview
      1. Configuring Parameter Data
      4. Import and Export Set File
      5. Preset Comparison
      9. Search in Parameter Sets
Signal Flow Designer
    1. Pin Labelling
    2. View Audio Object Metadata
    4. Upgrade Audio Object
    6. Metering the Signal Flow
    7. Copy and Paste Operation
    8. Undo and Redo Operation
    9. Block Control
    11. Securing Audio Objects
  4. Create a Signal Flow
  5. Tune a Signal Flow
  6. Native Panels
    1. Launching Native Panel
  11. Compound Audio Object
    2. Import and Export CAO
    3. Tuning and Editing CAO
    4. Create Preset for CAO
    5. Edit CAO Instance
    6. Set password for CAO
    8. Multi dll support for CAO
Audio Object Description
  2. Interface Objects
    1. AudioIO
    2. ControlIn
    3. ControlOut
  3. Basic Objects
    1. Delay
      1. Delay Panel
    2. Gain
      1. Gain Panel
    3. Level Monitor
      1. Level Monitor Panel
    4. Fader Balance
      1. Fader Balance Panel
    5. Volume and Mute
      1. Volume and Mute Panel
    6. VolumeLite
  4. Control Objects
    1. Control Math
    2. Control Grouper
    3. Control GroupSplitter
    4. Control Multi Adder
    5. Control Mixer
      1. Control Mixer panel
    6. Control Router
      1. Control Router panel
    7. Control Smooth
    8. AudioToControl
    9. Lookup Table (LUT)
      1. Lookup Table (LUT) Panel
    10. Control Generator
  5. Routing Objects
    1. Router
      1. Router Panel
    2. Demux
    3. Selector
  6. Source Objects
    1. Noise Generator
      1. Noise Generator Panel
    2. Wave Generator
    3. FilePlayer
  7. Mixer Objects
    1. Adder
    2. Matrix Mixer
      1. Matrix Mixer Panel
    3. Merger
    4. Fader Matrix
  8. Dynamic Object
    1. Limiter
      1. Limiter Panel
  9. Filter Objects
    1. ParameterBiquad
      1. Parameter Biquad Panel
    2. CoefficientBiquad
    3. Tone Control Extended
    4. XoverBiquad
      1. Xover Biquad Panel
    5. FastConv
      1. Fast Conv Panel
    6. FIR Filter
      1. FIR Filter Panel
Real Time Analyzer
  3. Settings
    1. Channels Settings
    2. Generator Settings
    3. Analyzer Settings
    4. Microphone Calibration
    5. RTA Advanced Settings
      1. Sound Card Settings
      2. Plugin Host Setting
      3. Advance Analyzer Settings
      4. Advance Generator Settings
      5. Graph Display Settings
      6. MIMO Convolver Settings
      7. Recorder Settings
      8. Routing Settings
  5. Probe Point Configuration
  6. Real Time Data View
  8. Traces
    1. Trace Toolbar
    2. Trace Configuration
    3. Trace Functionalities
    4. RTA Shortcuts
  9. Analysing Audio Signal
Measurement Module 2.0
  2. Configurations
    1. Device Output Mapping
    2. Generator
    3. Test Sound
    1. Scene Setup
    2. Speaker Configuration
    3. Microphone Configuration
    4. Define Measurement
    5. Measurement Session
Central Viewer
  1. Central Viewer Overview
  2. Central Viewer Window
    1. Configurations
    2. Scene Mode
    3. Chart Selector
    4. Waterfall Chart
    5. Graph Area
    6. Curve Lists
    7. Domain Selector
Starter Kit Utility Tool
  1. Starter Kit Utility Tool
3.11.Configure Control IDS
  • Global Tuning Tool
  • Configure Control IDS
The Control IDs are used to configure Custom Control IDs. Users can add, edit, export, and import Custom Control IDs data.
To open the Control IDs
  1. On the Device View, click on the Control IDs. This opens the Custom Control IDs configuration window.
    The Custom Control IDs window shows all the custom control ID details.
To add the custom control ID
  1. On the Custom Control IDs panel, click on Add. This opens the Add Control Signal window, where the user can enter the details of the new custom control.
    You need to enter details in all fields. The maximum value of control should be greater than the minimum value. The Control ID range should be between 61440 to 65535.
  2. Click OK to save the custom control id details.
To edit the custom control ID
  1. On the Custom Control IDs panel, click on the Edit icon. This opens the Edit Control Signal window, where the you can update or change the custom control details.
  2. Click OK to update the custom control id details.
To delete the custom control ID
  1. On the Custom Control IDs panel, click on the Delete icon. This deletes custom control and also removes its associated data.
To export the custom control ID
Using the export option, all custom control data can be exported in the provided destination directory with the file extension *.csv.
  1. On the Custom Control IDs panel, click on Export. This opens the file directory.
  2. Navigate to the desired location and click Save to export the file.
To import the custom control ID
Using the import option, all the custom control data can be imported to GTT.
  1. On the Custom Control IDs panel, click on Import. This action opens the file directory.
  2. Navigate to the file location and click Open to import the file.
This action will import all the custom control pins from the file (with *.csv extension) in the custom control list.
A message will appear if the file is invalid or does not contain the required data.
Graphical user interface, text Description automatically generated
If GTT contains custom control IDs, it will ask for confirmation whether the user wants to overwrite them.
An error message will be displayed if the import file contains duplicate control IDs.
Graphical user interface, application, website Description automatically generated
« Configure File controllerCustom Device Usage »
Suggest Edit
  • Careers
  • Contact
