Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
  • Getting Started
  • User Guides
  • Developer Guides
Table of Content
Global Tuning Tool
  1. About Global Tuning Tool
    1. System Requirements
  2. Workspace Overview
    1. Home Screen
      1. Home screen Options
      2. Application Options
    2. Device Designer Overview
      1. Tools
      2. Connection
      3. Import and Export
      4. Tuning
      5. Device Panels
    3. Devices and Template View
    4. About Core Objects Toolbox
    5. Device Operations
    6. Properties Panel
    7. Device View
    8. Help
  3. Configurations
    1. Configure State Variable
      2. Core Object Settings
      3. Custom Actions Settings
      5. Maintain Folder Structure
      7. Handling Dual Responses
      8. Send Preset Data Online
    4. Link Window
    5. Configure Controller
    6. Launch MIPS Profiling
    7. Launch Memory Profiling
    8. Editing Memory Latency
      1. Start Live Streaming
      2. Record Streaming Data
      3. FFT for Streaming
    10. Configure File controller
    11. Configure Control IDS
    12. Custom Device Usage
    13. Multi-xAF Library Support
  4. Operations
    1. Create a New Project
    2. Create Signal Flow
    3. Connecting a Device
    4. Routing (Connections)
    5. Device Synchronization
    7. Tune a Signal Flow
  5. Designing Custom Panel
    1. Panel Designer Ribbon
      1. Text Design
      2. Fader Design
      3. Rotary Design
      4. Button Design
      5. Box Design
      6. LED Design
      7. Meter Design
      8. Other Design
      9. Images
      10. Advanced
    2. Panels View
    4. Designer Workspace
    5. Editor Windows
      1. Parameter Address Editor
      3. System Function Editor
      5. Select Color Window
      6. Discrete Values Editor
      8. LED Values Editor
      9. Graph Parameters Window
      10. Scale Editor
  6. Working with Parameter Set
    1. Parameter Set Overview
      1. Configuring Parameter Data
      4. Import and Export Set File
      5. Preset Comparison
      9. Search in Parameter Sets
Signal Flow Designer
    1. Pin Labelling
    2. View Audio Object Metadata
    4. Upgrade Audio Object
    6. Metering the Signal Flow
    7. Copy and Paste Operation
    8. Undo and Redo Operation
    9. Block Control
    11. Securing Audio Objects
  4. Create a Signal Flow
  5. Tune a Signal Flow
  6. Native Panels
    1. Launching Native Panel
  11. Compound Audio Object
    2. Import and Export CAO
    3. Tuning and Editing CAO
    4. Create Preset for CAO
    5. Edit CAO Instance
    6. Set password for CAO
    8. Multi dll support for CAO
Audio Object Description
  2. Interface Objects
    1. AudioIO
    2. ControlIn
    3. ControlOut
  3. Basic Objects
    1. Delay
      1. Delay Panel
    2. Gain
      1. Gain Panel
    3. Level Monitor
      1. Level Monitor Panel
    4. Fader Balance
      1. Fader Balance Panel
    5. Volume and Mute
      1. Volume and Mute Panel
    6. VolumeLite
  4. Control Objects
    1. Control Math
    2. Control Grouper
    3. Control GroupSplitter
    4. Control Multi Adder
    5. Control Mixer
      1. Control Mixer panel
    6. Control Router
      1. Control Router panel
    7. Control Smooth
    8. AudioToControl
    9. Lookup Table (LUT)
      1. Lookup Table (LUT) Panel
    10. Control Generator
  5. Routing Objects
    1. Router
      1. Router Panel
    2. Demux
    3. Selector
  6. Source Objects
    1. Noise Generator
      1. Noise Generator Panel
    2. Wave Generator
    3. FilePlayer
  7. Mixer Objects
    1. Adder
    2. Matrix Mixer
      1. Matrix Mixer Panel
    3. Merger
    4. Fader Matrix
  8. Dynamic Object
    1. Limiter
      1. Limiter Panel
  9. Filter Objects
    1. ParameterBiquad
      1. Parameter Biquad Panel
    2. CoefficientBiquad
    3. Tone Control Extended
    4. XoverBiquad
      1. Xover Biquad Panel
    5. FastConv
      1. Fast Conv Panel
    6. FIR Filter
      1. FIR Filter Panel
Real Time Analyzer
  3. Settings
    1. Channels Settings
    2. Generator Settings
    3. Analyzer Settings
    4. Microphone Calibration
    5. RTA Advanced Settings
      1. Sound Card Settings
      2. Plugin Host Setting
      3. Advance Analyzer Settings
      4. Advance Generator Settings
      5. Graph Display Settings
      6. MIMO Convolver Settings
      7. Recorder Settings
      8. Routing Settings
  5. Probe Point Configuration
  6. Real Time Data View
  8. Traces
    1. Trace Toolbar
    2. Trace Configuration
    3. Trace Functionalities
    4. RTA Shortcuts
  9. Analysing Audio Signal
Measurement Module 2.0
  2. Configurations
    1. Device Output Mapping
    2. Generator
    3. Test Sound
    1. Scene Setup
    2. Speaker Configuration
    3. Microphone Configuration
    4. Define Measurement
    5. Measurement Session
Central Viewer
  1. Central Viewer Overview
  2. Central Viewer Window
    1. Configurations
    2. Scene Mode
    3. Chart Selector
    4. Waterfall Chart
    5. Graph Area
    6. Curve Lists
    7. Domain Selector
Starter Kit Utility Tool
  1. Starter Kit Utility Tool
5.1.2.Fader Design
  • Global Tuning Tool
  • Fader Design
Fader Horizontal
A Fader Horizontal is an adjustable horizontally-positioned fader control that manipulates a device parameter.
Controls can be managed in the Custom Panel designer and, once the Custom Panel is activated, utilized by the end user. This control must be linked to a parameter to function properly.
Fader Vertical
A vertical fader is an adjustable vertically-positioned control that manipulates a device parameter.
Fader Multi Parameter
A multiparameter fader manipulates multiple device parameters.
On an activated Custom Panel, levels on a multiparameter fader can be adjusted together or individually
Common Fader Design Properties
Properties Type
Description
General
  • Control Info: Shows control type. This propery is Read only.
  • Locked: Specifies if the control is locked out so that it cannot be moved or re-sized.
    • Checked = Locked
    • Unchecked = Unlocked
Parameters
  • Addresses: Enables panel designer to edit addressing information with the added benefit that the values can be validated as a group before being applied to the device.
    This editor also allows the user to assign multiple parameters to the control. Click to select Parameter Address Editor.
    • Properties correspond to the system explorer.
  • Information: Shows information about the Parameter Address.
    • Read only. Properties correspond to the system explorer
  • Maximum: Maximum parameter value.
    • The largest parameter value.
  • Minimum: Minimum parameter value.
    • The smallest parameter value.
  • Reset Text: Optional text to display in right click context popup.
Appearance
  • Location: Control location (in pixels) of the control on the Custom Panel. Change X (horizontal) and Y (vertical) values in relation to upper left corner.
    You can also drag the control to a different location
  • Size: Control size (in pixels). Change width and height values. You can also re-size the control manually
  • Background Image: Brings up the Select Background Image window
  • Background Color: Background color of the control
  • Tool Tip Text: The text that appears on control mouse-over.
  • Tab Index: Determines the position of the control in the tab order
  • Tab Stop: Specifies whether the control appears in the tab order.
    • Checked = Appears
    • Unchecked = Does not appear
Arrow
  • Maximum Arrows: The maximum number of arrows to display.
  • Arrow Direction: The direction the arrows should point.
    • Point Left or Point Right
Fader Cap
  • Fader Cap Image: The image displayed for the fader cap.
    • Click Browse to locate custom fader caps
  • Fader Cap Size: How large the fader cap will be
  • Arrow Box Width: The width of the arrow box in pixels
  • Vertical Offset: The vertical offset of the fader cap, in pixels, from the fader channel
  • Horizontal Offset: The horizontal offset of the fader cap, in pixels, from the fader channel
  • Hot Spot: Sets mouse sensitivity to the fader cap or the entire length of the slider
  • Highlight Color: The channel highlight color
  • Arrow Box Separation: The distance between the arrow box and the fader channel in pixels.
  • Label Margin: The amount of space, as a decimal fraction of the width of the control, between the center channel and the tick marks
Channel
  • Channel Color: Color of the fader channel. Default is Dim Gray
  • Channel Width: Width of the fader channel in pixels
  • Channel Start: Distance, as a percentage of length, from the bottom or left edge to where the fader channel will start.
  • Channel End: Distance, as a percentage of length, from the bottom or left edge to where the fader channel will end.
  • Channel Center: Distance, as a percentage of width, from the bottom or left edge to where the fader channel will be located.
Scale
  • Display Tick Marks: Option to display the tick marks of the control. Must be set to true for custom ticks to display.
    • Checked = Display
    • Unchecked = Do not display
  • Number of Major Ticks: How many major ticks are displayed.
  • Tick Location: The location of the tick marks relative to the fader channel.
  • Custom Ticks: Whether to use custom tick values by utilizing the scale editor or not.
    • Checked = Display
  • Display Tick Values: The value of the ticks to be displayed.
  • Value Format: The format of the tick values.
  • Labels Inside:
  • Major Tick Color: The color of the major tick.
  • Major Tick Length: The length of the major tick.
  • Number of Minor Ticks: How many minor ticks are displayed.
  • Minor Tick Color: The color of the minor tick.
  • Minor Tick Length: The length of the minor tick.
  • Font: The font for the ticks.
  • Labels Inside: Whether labels are drawn between tick marks and fader channel.
    Whether labels are drawn between tick marks and fader channel or not.
    • Checked = labels drawn between tick marks and channel.
    • Unchecked = tick marks drawn between labels and channel.
  • Labels Vertical: Whether labels are displayed vertically or horizontally.
    • Checked = labels display vertically
    • Unchecked = labels display horizontally, left to right.
  • Label Margin: The amount of space, as a decimal fraction of the width of the control, between the center channel and the tick marks.
Nudge Button
  • Nudge Button Location: Location of the nudge buttons.
    • None, Center, Above or Below
  • Nudge Type: Determines, with the increment amount, how much the control will adjust when a nudge button is pressed.
    • Percent – percentage of the total visual display of the control. For non-logarithmic controls, the visual display and the total value of the control will be the same. For logarithmic controls, the visual display will differ from the total value.
    • Bump – small increment
    • Value – specified increment amount.
  • Increment Amount: Determines, with the nudge type, how much the control will adjust when a nudge button is pressed.
  • Nudge Button Separation: Distance, in pixels, from the edge to the nudge button.
  • Up Image: The static image for the “up” nudge button. Click the button to select a new image.
  • Up Pushed Image: The image that displays when the “up” nudge button is pushed. Click the button to select a new image.
  • Down Image: The static image for the “down” nudge button. Click the button to select a new image.
  • Down Pushed Image: The image that displays when the “down” nudge button is pushed. Click the button to select a new image.
Popup Value
  • Popup Value Position – Fraction: The location of the popup value as a decimal fraction of the width (X) and height (Y) of the control.
  • Display Popup Value: Displays the value of the control in a popup, if set to true
    • Checked = Display
« Text DesignRotary Design »
Suggest Edit
  • Careers
  • Contact
