Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
Harman Logo
AUDIOWORX
  • Home
  • Documentation
  • Videos
  • Release Notes
  • Login
  • Getting Started
  • User Guides
  • Developer Guides
Table of Content
Global Tuning Tool
  1. About Global Tuning Tool
    1. System Requirements
  2. Workspace Overview
    1. Home Screen
      1. Home screen Options
      2. Application Options
    2. Device Designer Overview
      1. Tools
      2. Connection
      3. Import and Export
      4. Tuning
      5. Device Panels
    3. Devices and Template View
    4. About Core Objects Toolbox
    5. Device Operations
    6. Properties Panel
    7. Device View
    8. Help
  3. Configurations
    1. Configure State Variable
      2. Core Object Settings
      3. Custom Actions Settings
      5. Maintain Folder Structure
      7. Handling Dual Responses
      8. Send Preset Data Online
    4. Link Window
    5. Configure Controller
    6. Launch MIPS Profiling
    7. Launch Memory Profiling
    8. Editing Memory Latency
      1. Start Live Streaming
      2. Record Streaming Data
      3. FFT for Streaming
    10. Configure File controller
    11. Configure Control IDS
    12. Custom Device Usage
    13. Multi-xAF Library Support
  4. Operations
    1. Create a New Project
    2. Create Signal Flow
    3. Connecting a Device
    4. Routing (Connections)
    5. Device Synchronization
    7. Tune a Signal Flow
  5. Designing Custom Panel
    1. Panel Designer Ribbon
      1. Text Design
      2. Fader Design
      3. Rotary Design
      4. Button Design
      5. Box Design
      6. LED Design
      7. Meter Design
      8. Other Design
      9. Images
      10. Advanced
    2. Panels View
    4. Designer Workspace
    5. Editor Windows
      1. Parameter Address Editor
      3. System Function Editor
      5. Select Color Window
      6. Discrete Values Editor
      8. LED Values Editor
      9. Graph Parameters Window
      10. Scale Editor
  6. Working with Parameter Set
    1. Parameter Set Overview
      1. Configuring Parameter Data
      4. Import and Export Set File
      5. Preset Comparison
      9. Search in Parameter Sets
Signal Flow Designer
    1. Pin Labelling
    2. View Audio Object Metadata
    4. Upgrade Audio Object
    6. Metering the Signal Flow
    7. Copy and Paste Operation
    8. Undo and Redo Operation
    9. Block Control
    11. Securing Audio Objects
  4. Create a Signal Flow
  5. Tune a Signal Flow
  6. Native Panels
    1. Launching Native Panel
  11. Compound Audio Object
    2. Import and Export CAO
    3. Tuning and Editing CAO
    4. Create Preset for CAO
    5. Edit CAO Instance
    6. Set password for CAO
    8. Multi dll support for CAO
Audio Object Description
  2. Interface Objects
    1. AudioIO
    2. ControlIn
    3. ControlOut
  3. Basic Objects
    1. Delay
      1. Delay Panel
    2. Gain
      1. Gain Panel
    3. Level Monitor
      1. Level Monitor Panel
    4. Fader Balance
      1. Fader Balance Panel
    5. Volume and Mute
      1. Volume and Mute Panel
    6. VolumeLite
  4. Control Objects
    1. Control Math
    2. Control Grouper
    3. Control GroupSplitter
    4. Control Multi Adder
    5. Control Mixer
      1. Control Mixer panel
    6. Control Router
      1. Control Router panel
    7. Control Smooth
    8. AudioToControl
    9. Lookup Table (LUT)
      1. Lookup Table (LUT) Panel
    10. Control Generator
  5. Routing Objects
    1. Router
      1. Router Panel
    2. Demux
    3. Selector
  6. Source Objects
    1. Noise Generator
      1. Noise Generator Panel
    2. Wave Generator
    3. FilePlayer
  7. Mixer Objects
    1. Adder
    2. Matrix Mixer
      1. Matrix Mixer Panel
    3. Merger
    4. Fader Matrix
  8. Dynamic Object
    1. Limiter
      1. Limiter Panel
  9. Filter Objects
    1. ParameterBiquad
      1. Parameter Biquad Panel
    2. CoefficientBiquad
    3. Tone Control Extended
    4. XoverBiquad
      1. Xover Biquad Panel
    5. FastConv
      1. Fast Conv Panel
    6. FIR Filter
      1. FIR Filter Panel
Real Time Analyzer
  3. Settings
    1. Channels Settings
    2. Generator Settings
    3. Analyzer Settings
    4. Microphone Calibration
    5. RTA Advanced Settings
      1. Sound Card Settings
      2. Plugin Host Setting
      3. Advance Analyzer Settings
      4. Advance Generator Settings
      5. Graph Display Settings
      6. MIMO Convolver Settings
      7. Recorder Settings
      8. Routing Settings
  5. Probe Point Configuration
  6. Real Time Data View
  8. Traces
    1. Trace Toolbar
    2. Trace Configuration
    3. Trace Functionalities
    4. RTA Shortcuts
  9. Analysing Audio Signal
Measurement Module 2.0
  2. Configurations
    1. Device Output Mapping
    2. Generator
    3. Test Sound
    1. Scene Setup
    2. Speaker Configuration
    3. Microphone Configuration
    4. Define Measurement
    5. Measurement Session
Central Viewer
  1. Central Viewer Overview
  2. Central Viewer Window
    1. Configurations
    2. Scene Mode
    3. Chart Selector
    4. Waterfall Chart
    5. Graph Area
    6. Curve Lists
    7. Domain Selector
Starter Kit Utility Tool
  1. Starter Kit Utility Tool
5.1.8.Other Design
  • Global Tuning Tool
  • Other Design
Tick Marker
A tick marker is an unlinked control that can be customized to show user-specified values. It can be used with faders and meters to specify particular measurements with unique positions, orientations, colors, etc.
Controls can be managed in the Custom Panel designer and, once the Custom Panel is activated, utilized by the end user. This control must be linked to a parameter to function properly.
 Property Type Options
General
  • Control Info: Shows control type. This propery is Read only.
  • Locked: Specifies if the control is locked out so that it cannot be moved or re-sized.
    • Checked = Locked
    • Unchecked = Unlocked
Appearance
  • Location: Control location (in pixels) of the control on the Custom Panel. Change X (horizontal) and Y (vertical) values in relation to upper left corner.You can also drag the control to a different location.
  • Size: Control size (in pixels).Change width and height values. You can also re-size the control manually.
  • Background Color: The background color of the text areaBrings up the Select Color window.
Ticks
  • Vertical Justification: Vertical justification of the ticks
  • Display Ticks: Whether to display the tick marks of the control or not
    • True = displayed
    • False = not displayed
  • Major Tick Color: Color of the major ticks. Brings up the Select Color window.
    • Default is black
  • Major Tick Count: How many major ticks are displayed. The major tick count must be the same as or larger than the number of major tick labels in order to display all labels.
  • Major Tick Length: The length (in pixels) of the major ticks
  • Orientation: Displayed Horizontal or Vertical
  • Minor Split: Whether or not to split minor ticks on the centered tick marker.
  • Minor Tick Color: Color of the minor ticks. Brings up the Select Color window.
    • Default is blue
  • Minor Tick Count: How many minor ticks are displayed between major ticks
  • Minor Tick Length: The length (in pixels) of the major tick
  • Tick Thickness: Thickness (in pixels) of the tick marks.
Tick Labels
  • Display Labels: Whether or not to display labels on the control.
  • Label Font: Click on “…” to select desired font. Choose from Windows fonts
  • Label Color: Color of the control text. Brings up the Select Color window.
    • Default is black
  • Tick Label Offset: Spacing (in pixels) between tick marks and their labels.
  • Major Tick Labels: The labels for the major ticks. The major tick count must be the same as or larger than the number of major tick labels to display all labels.
Margins
  • High Margin: Spacing (in pixels) between label and top border, limited by size of bounding box.
  • Left Margin: Spacing (in pixels) between label and left border, limited by size of bounding box.
  • Low Margin: Spacing (in pixels) between label and bottom border, limited by size of bounding box.
  • Right Margin: Spacing (in pixels) between label and right border, limited by size of bounding box.
Note
A note adds an icon to a Custom Panel with popup text. A note cannot be linked to a parameter. Controls can be managed in the Custom Panel designer and, once the Custom Panel is activated, viewed (but not changed) by the end user.
General
    • Checked = Locked
Appearance
  • Size: Control size (in pixels). Change width and height values. You can also re-size the control manually.
  • Background Color: Background color of the control.
  • Tool Tip Text: Text that appears on control mouse-over.
Note
  • Note Text: Click to enter desired text for note content. Brings up a Control Text editor.
  • Text Color: Text color of the control. Brings up the Select Color window.
    • Default color is black
  • Popup Background Color: Background color for the popup. Brings up the Select Color window.
  • Popup Width: The width of the popup in pixels
  • Popup Height: The height of the popup in pixels
  • Display Direction: The direction in which the popup will appear when the note is clicked. “Auto” will position the popup depending on where the user clicks.
    • Left Up
    • Down Right
    • Upper left Upper right
    • Lower left Lower right
Panel Link
A panel link is a control on a Custom Panel that links to another Custom Panel. Define the link in the panel link section of the properties tab.
Controls can be managed in the Custom Panel designer and, once the Custom Panel is activated, utilized by the end user. This control must be linked to another Custom Panel to function properly.
Appearance
  • Background Color: The background color of the text area. Brings up the Select Color window.
  • Background Image: Background image of the control. Brings up the Select Color window.
  • Background Image Layout: Background layout of the image. Tile, Centre, Stretch, and Zoom
  • Font: Click on “…” to select desired font. Choose from Windows fonts.
  • Foreground Color: The foreground color for the panel. Brings up the Select Color window.
Design
  • Panel Name: Enter the name of the panel. Default text is “Panel 1”.
Layout
  • Start Behavior: Behavior of the panel. Manual, CenterScreen, and WindowsDefaultLocation.
  • Start Location: Control location (in pixels) of the control on the Custom Panel. Change X (horizontal) and Y (vertical) values in relation to upper left corner. You can also drag the control to a different location
Window Style
  • Show Control Box: Whether to display control box or not.
  • Form Border Style: Click to select form border style.
    • FixedSingle
    • Fixed3D
    • FixedDialog
    • FixedToolWindow
    • Sizable
    • SizableToolWindow
  • Hide Cursor: Whether or not to display cursor.
  • Icon: Click on “…” to select desired icon.
  • Show Maximize Box: Whether to display maximize box or not.
  • Show Minimize Box: Whether to display minimize box or not.
  • Show Icon: Whether to display icon or not.
  • Show in Taskbar: Whether to display taskbar or not.
  • Size Grip Style: Click to select size grip style. Auto, Show, and Hide
Panel Preset Bar
The panel preset bar manages panel presets. This control is added to the Custom Panel as an unlinked control because it is not linked to a parameter; it creates values as you change parameter settings.
On an activated Custom Panel, you can store, recall, rename, and delete panel presets. On the Custom Panel designer, you can edit it or change its properties.
A panel preset saves the current values and control parameters on a Custom Panel; when additional parameters are added or values are changed, the panel preset must be saved again to include them.
  • Store panel preset: On the activated Custom Panel, change parameter settings as desired then click “Store” on panel preset bar.
On Store Panel Preset dialog, type preset name, and click “OK.” The panel preset is added to the preset list.
If one of the values on a panel preset is changed, the button will turn green to alert you that you need to re-save the panel preset to include the changed value. Simply click the ‘Store’ button.
  • Recall panel preset: Recall panel presets on the activated Custom Panel, either from the title bar or the panel preset bar.
    • TITLE BAR: Right click title bar, select “Recall Preset,” then select the desired preset from the list.
    • PANEL PRESET BAR: Select “Recall.” Select the panel preset from the list and click “OK.”
The panel preset settings are recalled.
  • Rename panel preset: On the activated Custom Panel, select “Store” on panel preset bar. Select the item from the list that you wish to rename.
Type the new name next to “Preset Name” and click “OK.”
  • Delete panel preset: On the activated Custom Panel, select “Delete.” Select the panel preset from the list and click “OK.”
General
    • Checked = Locked
Appearance
  • Font: Click on “…” to select desired font. Selects from Windows fonts.
  • Label Text Color: The color of the Label Text
    • Brings up the Select Color window.
  • Tab Index: Indicates the sequence of an element within the tabbing order of all focusable elements in the document.
  • Tab Stop: Whether the control appears in the tab order.
    • Checked = Appears
    • Unchecked = Won’t appear
« Meter DesignImages »
Suggest Edit
  • Careers
  • Contact
