Control Demux
The Control demux audio object routes the input control signal to one of the control outputs based on the index value.
Control Demux Properties
The table below describes the audio object properties and functionalities.
Properties Description
Number of ControlOuts Enter the number of control outputs.
  • Range: 2 to 255
  • Default: 2
Display Name Display the name of the Control demux audio object in the signal flow design. It can be changed based on the intended usage of the object.
Mode
There are currently no modes available for the Control demux audio object.
Additional parameters
There are no additional parameters available for the Control demux audio object.
Tuning Parameters
The output index, which selects the control output through which the control input will be routed, could be changed as a tuning parameter.
Parameter Description Data Type Range Default Unit
Output Index Selects the output through which the input will be routed. Unsigned Int 0 – (Number of control outputs -1) 0 none
Control Interface
There are two control inputs for the Control demux.
The first receives the control input. The second selects the control output through which the input will be routed.
Name Description Data Type Range Unit
Control Input Receives the control input. Float Min: single precision float minimum -3.402823 x 10^38
Max: single precision float maximum 3.402823 x 10^38
None
Output Index Selects the output through which the input will be routed. Float Min: 0
Max: Number of control outputs – 1
None
Native Panel
Control demux audio object does not support a native panel.
