Panel Designer Components
The Panel Designer includes several features grouped into categories to assist you in designing custom panels effectively.
  1. Panel Designer Ribbon: The Panel Designer ribbon contains tools for designing and editing the custom panel. The ribbon is divided into the following groups: Tools, Current Panel, Controls, Clipboard, Editing, Layout, and Parameters.
    The Panel Designer ribbon contains tools for designing and editing custom panels.
    The Panel Designer ribbon comprises the following groups.
  2. Panels View: The Panels view in Panel Designer displays all the custom panels and allows you to create, delete, and import the custom panels. In addition, you can access the Venue Explorer to view available devices, Applications, and Parameter Sets.
  3. Custom Panel Properties View: The Properties view displays the properties of each component used to design the custom Panel and also allows you to customize the Panel to meet your needs. The Properties view is displayed on the right-hand side of the screen.
  4. Designer Workspace: You can use various tools available in the Toolbox to create a custom panel in the Designer workspace.
  5. Editor Windows: In the Properties view, you can customize the Panel using various editor windows. These editor windows are mapped to the corresponding properties.
