Panel Designer Ribbon
The Panel Designer ribbon contains a tool for designing and editing the custom panel.
The Panel Designer ribbon comprises the following groups.
  • Controls
  • Clipboard
  • Editing
  • Panels
  • Layout
  • Parameters
Groups Descriptions
Controls
The Control group comprises of designer tools that allow you to design the custom panel. This includes Basic, Image, Advanced, Group, and Ungroup.
Clipboard
The Clipboard group is a set of copy and paste menus. This includes Duplicate, Cut, Copy, Paste, Copy Visual, and Paste Visual.
  • Duplicate: Duplicates the selected control.
  • Duplicate Special: Brings up the following window.
    Graphical user interface, application Description automatically generated
  • Cut / Copy / Paste: Acts as standard Windows function in that you may Cut/ Copy/ Paste the selected control.
  • Copy Visual / Paste Visual: This brings up the Select Control Properties window.
The visual properties of a single control are copied and pasted with the appropriate menu entry in the right-click context menu for a selection of controls, and with the appropriate button in the Clipboard control group within the Custom Panel Designer pop-up Ribbon.
Editing
The Editing group is a set of edit menus. This includes Delete, Select All, Undo, and Redo.
  • Delete: You may delete a selected device or multiple selections of devices from the Venue using the Delete button or with the Delete keyboard key.
  • Select All: Use this to select all devices within the current view, or with the standard CTRL-A Windows keyboard shortcut.
  • Undo / Redo: Use these buttons to Undo or Redo all operations or with the standard CTRL-Z (Undo), and CTRY-Y (Redo) Windows keyboard shortcuts.
Panels
  • Launch Current: This option allows you to open the current active Custom Panel.
  • Duplicate: This option allows you to create a copy of the current active Custom Panel.
  • Create Link: This option allows you to create a link on a custom panel.
Layout
The Layout group is a set of tools that allow you to arrange your design items just the way you want them. This includes Align tools, Size tools, Spacing tools, and Order tools.
  • Align: A drop-down menu to align the current selection(s) within the panel.
  • Size: Drop-down menu with options for sizing the current selection(s) as Size to Grid, Make the Same Width, Make the Same Height, or make all selected controls the Same Size.
  • Spacing: Drop-down menu with options for spacing the controls within the Panel.
  • Order: Bring-to-Front or Send-to-Back options for selected controls.
Parameters
The tools in the Parameter group allow you to Edit, Remove, and Search the parameters.
  • New Link:
  • Add To Link:
  • Edit: Click to select Parameter Address Editor.
  • Remove: Removes the selected parameters.
  • Search: Brings up the Advanced Parameter Search window.
  • Readdress:
