Audio Object Workflow
Design Time Work flow
The work flow during design time is described below. Design time is when the user is creating a signal flow from the Signal Flow Design tool within GTT. These are the interactions that go on between the tool and dll loaded into the tool:
Runtime Workflow
The workflow during runtime between the framework class, CAudioProcessing, and the audio objects base class, CAudioObject, is described below.
