Control GroupSplitter
The Control GroupSplitter audio object splits one control group input into multiple individual control outputs.
Use Case: This object can be deployed if user wants to split the block control to individual control signals which needs to be connected to different audio objects.
Control GrouperSplitter Properties
Below table describes about the Control GroupSplitter audio object properties and functionality.
Properties Description
# of controls in Group Enter the number of control outputs. It is also the number of signals within the one group to control input.
The number of control group input is always 1.
  • Range: 2 to 128
  • Data type: xFloat32
  • The default value is set to 2.
The Control GroupSplitter audio object accepts a single block control at its input and splits it into a user-configurable number of single control outputs.
Display Name Display name of the Control GrouperSplitter audio object in signal flow design. It can be changed based on the intended usage of the object.
Mode
There are no mode available for Control GroupSplitter audio object.
Additional parameters
There are no additional parameters available for Control GroupSplitter audio object.
Tuning Parameters
There are no tuning parameters available for Control GroupSplitter audio object.
Control Interface
The object always has N single control outputs. The number N is described via the number of elements variable in SFD. The object always has one group control input.
Native Panel
Control GroupSplitter audio object does not support native panel.
