Control IDS
The Control IDs are used to configure Custom Control IDs. Users can add, edit, export, and import Custom Control IDs data.
To open the Control IDs
  1. On the Device View, click on the Control IDs. This opens the Custom Control IDs configuration window.
    The Custom Control IDs window shows all the custom control ID details.
To add the custom control ID
  1. On the Custom Control IDs panel, click on Add. This opens the Add Control Signal window, where the user can enter the details of the new custom control.
    You need to enter details in all fields. The maximum value of control should be greater than the minimum value. The Control ID range should be between 61440 to 65535.
  2. Click OK to save the custom control id details.
To edit the custom control ID
  1. On the Custom Control IDs panel, click on the Edit icon. This opens the Edit Control Signal window, where the you can update or change the custom control details.
  2. Click OK to update the custom control id details.
To delete the custom control ID
  1. On the Custom Control IDs panel, click on the Delete icon. This deletes custom control and also removes its associated data.
To export the custom control ID
Using the export option, all custom control data can be exported in the provided destination directory with the file extension *.csv.
  1. On the Custom Control IDs panel, click on Export. This opens the file directory.
  2. Navigate to the desired location and click Save to export the file.
To import the custom control ID
Using the import option, all the custom control data can be imported to GTT.
  1. On the Custom Control IDs panel, click on Import. This action opens the file directory.
  2. Navigate to the file location and click Open to import the file.
This action will import all the custom control pins from the file (with *.csv extension) in the custom control list.
A message will appear if the file is invalid or does not contain the required data.
Graphical user interface, text Description automatically generated
If GTT contains custom control IDs, it will ask for confirmation whether the user wants to overwrite them.
An error message will be displayed if the import file contains duplicate control IDs.
Graphical user interface, application, website Description automatically generated
