Control Router
The Control Router audio object provide a mechanism to route control signal from input to output. The router allows to change path of control signal during runtime, which allows for flexibility when designing audio signal pipeline.
This object can be deployed whenever different control inputs to be routed to an object.
It can have arbitrary number of inputs and outputs ranging from 1 to 254 and enables the inputs to be cut or copied to any number of outputs.
Control Router Properties
A screenshot of a computer Description automatically generated
Properties Description
Display Name Display name of the Control Router audio object in signal flow design. It can be changed based on the intended usage of the object.
Mode
There are no mode available for Control Router audio object.
Additional Parameters
Parameter Description
Number of control input and output The max input and output in additional configuration is 100.
Range: 1 to 254
The default number of control input and output pin is 1.
Tuning Parameters
There are no tuning parameters available for Control Router audio object.
Control Interface
Default control input output is 1 and configurable through additional configuration from 1 to 254 max.
