Enabling Streaming Functionality
Now, if you want to measure the audio signal output and control output of an audio object of the added device. You need to configure Streaming functionality in a signal flow design.
  1. Go to the Device Designer window and select the virtual core of the device.
  2. Go to the virtual core properties and select the Streaming checkbox to enable streaming functionality.
    A screenshot of a computer Description automatically generated
  3. Enter the desired number of Level Meters that need to be added to the signal flow to monitor control-out connections or audio.
  4. Click Save to save the changes and click on Send Device Config.
  5. Double-click on the Xaf Instance to open the Signal Flow Designer window.
  6. On the Signal Flow Designer window, right-click on the audio connections, and select Level Meter > RMS. This action adds Level Meters in the signal flow design.
    A screenshot of a computer Description automatically generated A screenshot of a computer Description automatically generated
  7. Open Preset Controllers, click on Add Slot, and set Group 1 as LFHighOnly.
  8. Similarly, add another slot and set Group 1 as AllSpeakers.
  9. Click on Send to Device. When the preset data has been successfully sent, a completion message is displayed to indicate that the transmission was successful.
    If an error occurs, an error message is displayed.
  10. Click on Load Slot. The GTT sends a slot load request to the device and waits for a response.
    If the device is successfully loaded into the slot, a success message is displayed on the screen. Now you can perform tuning.
  11. Double-click on the audio object to open the native panel. On the native panel, change the value using the slider and check the level meter value.
  12. Similarly, open the IVP RTA window, go to the native panel, change the value using the slider, and check the signal graph.A screenshot of a computer Description automatically generated
