Loading Slots on the Device
If a set of files and slot map files are already available on the device.
  1. Click on the column header of the slot and select the slot, which has to be loaded to the device. Selected Slot Id is displayed in a text box under the DSP commands section.
  2. Click on the Load Slot button.
    By default, the first valid slot in the table is loaded. If the device is offline, it will be automatically connected to it.
The GTT sends a slot load request to the device and waits for a response. If the device is successfully loaded into the slot, a success message is displayed on the screen.
An error message will be displayed on the screen if the device has failed to load into the slot.
If a slot does not exist in the table but is present on the device, it is also possible to load it. In this case, the user can manually enter the slot ID and click on the “Load slot” button.
