MM IR-Settings
The Measurement ribbon consists of the following groups.
  • Import/Export: Using the Import and Export option you can configure the import and export setting of the measurement module. For more details refer, to Import and Export Settings.
  • Reset All: Using the “Reset All” option you can reset parameters used for the measurement setup (scene, speaker mapping, mic mapping, and measurement session).
  • Sound Settings: In the Sound Settings group you can configure Device Output Mapping, Generator, and Test Sound settings. For more details refer to Sound Settings.
The entire ribbon bar will not function once a measurement session is active, it will re-function after it ends since the settings made here do not affect an active measurement session.
Import MM IR Setting
The import menu allows you to import parameters available in the specified file.
Following are the parameters you can import.
  • Chosen scene
  • Device output mapping
  • Configured speakers
  • Configured microphones
  • Defined measurement sequences
These settings can be imported individually or together. Only the selection of the sequence import forces the import of speakers and microphones to guarantee consistency.
The import for the device output mapping will throw a warning if the project does not match the original project.
Export MM IR Settings
The export allows you to export all setup-related parameters.
Following are the parameters you can export.
  • Chosen scene
These settings can be exported individually or together. Only the selection of the sequence export forces the export of speakers and microphones to guarantee consistency upon re-import.
Sound Settings
In this group, you can configure Device Output Mapping, Generator, and Test Sound parameters. These menus are accessible during every step of the measurement preparation.
  • Device Output Mapping: The device output mapping menu allows for the mapping of gain channels to device output channels.
  • Generator: The generator menu is used to define parameters for the signal used in measurements. Using the drop-down option you can select Generator mode.
  • Test Sound: The Test Sound menu is used to set the parameters for the test sound.
