Panel Designer Overview
The Panel Designer comprises of various features, that offer you a thoughtfully designed, clean, and easy-to-use workspace. Using Panel Designer, you can quickly create a custom panel with all the elements you need and link the panel with a desired audio object. Let us have a look at some of the components of the Panel Designer workspace.
  1. Panel Designer Ribbon: The Panel Designer ribbon contains tools for designing and editing the custom panel. The ribbon is divided into the following groups: Tools, Current Panel, Controls, Clipboard, Editing, Layout, and Parameters.
    The Panel Designer ribbon contains tool for designing and editing the custom panel.
    The Panel Designer ribbon comprises the following group.
  2. Panels View: The Panels view in Panel Designer displays all the custom panels and allows you to create, delete and import the custom panels. In addition, you can access the Venue Explorer to view available Device(s), Applications, and Parameter Sets.
  3. Custom Panel Properties View: The Properties view displays the properties of each component used to design the custom Panel and also allows you to customize the Panel to meet your needs. The Properties view is displayed on the right-hand side of the screen.
  4. Designer Workspace: You can use various tools available in the Toolbox to create a custom panel in the Designer workspace.
  5. Editor Windows: In the Properties view you can customize the Panel using various editour windows. These editour windows are mapped with corresponding properties.
