Scale Editor
The Scale Editor provides a way to customize ticks on a fader or rotary control.
  • Type: Select between Real Values (default), Arbitrary or .
  • Real Values: Shows the actual values on the control. The Values may be edited.
    A screenshot of a cell phone Description automatically generated with medium confidence
  • Arbitrary: This shows the values of the table in two columns. The left column lists the actual values and the right column lists their corresponding labels.
    A screenshot of a phone Description automatically generated with medium confidence
  • : Default settings or the display settings from the device panel.
  • Ticks: List of the ticks shown on the control.
    • Add: Adds a new tick.
    • Remove: Removes the selected tick.
    • Default: Resets the ticks back to the default setting.
  • Manipulate Values: Edits the selected tick.
  • Value: Changes the actual value of the control.
  • Label: Sets what the tick will display as the control in the panel.
  • Generate New Values: Automatically Generate Ticks using the following properties.
  • Anchor: Reference point where the automatically generated ticks will cross.
  • Step: Sets the initial spacing between the anchor and the next tick.
  • Linear: Sets the spacing between each automatically created tick to the Step value.
  • Logarithmic: Spaces the automatically created ticks logarithmically with respect to the anchor.
  • Integers: Automatically changes the labels to integers starting with the lowest tick value at 0.
