In the Signal Flow Designer, you can view static metadata and dynamic metadata of an audio object.
Static Metadata
Static metadata refers to the metadata information of an audio object that does not change frequently. By default, every object available in the toolbox has the static metadata. Right-click on the audio object in the toolbox section to view the static metadata details.
On the metadata dialog box, the following metadata information displayed.
Dynamic Metadata
Dynamic metadata includes metadata information of an audio object that changes frequently or is generated in real-time. Every audio object instance in the signal flow designer has dynamic metadata. Right-click on the audio object in the signal flow designer to view the dynamic metadata details.
Metadata will also show which core types of the audio object supports. If the CoreTypes node is blank, this indicates all core types are supported.
