Copy and Paste Operation
The signal flow designer offers the capability to copy and paste audio objects, which can accelerate the design process. You can select a complete signal flow or a part of the signal flow. All the audio object properties will be copied along with UI properties.
Additionally, you can copy and paste the compound audio object.
Use the CTRL+C shortcut to copy selected audio objects and CTRL+A  & CTRL+C to copy the entire signal flow design.
To copy the single audio object follow the below steps:
  1. In the signal flow designer, right-click on an object and select Copy from the context menu or use CTRL+C to copy.
    After the object or signal flow design is copied, you can paste it into the same or a different framework instance.
  2. Right-click on the signal flow designer and select Paste from the context menu or use CTRL+V to paste the audio object.
To copy the multiple audio objects follow the below steps:
  1. In the signal flow designer, hold the Ctrl key and click on each object you want to copy or use CTRL+A to select all objects in the designer.
  2. Right-click on the selected objects and choose Copy selected items from the context menu or use the keyboard shortcut Ctrl+C.
  3. Right-click on the desired location in the signal flow designer where you want to paste the copied objects, select Paste from the context menu or use the keyboard shortcut Ctrl+V.
Copy and paste operations can also be performed outside the audio object selection.
