Preset or Tuning sets can be used to store the tuning data set of a CAO template signal flow. These stored tuning sets can be applied on instances of CAO template.
Preset control feature is available for all saved CAO templates. It can be used to store the tuning data set of CAO template.
To create Preset
- On the Compound Audio Object editor, tune audio objects signal flow.
- Select a free preset slot (numbers), enter a slot name in the text box.
- Click on Store Preset to save and store the preset. The preset will be stored in the slot you had chosen. The blue color indicates that the preset is applied to CAO inner audio objects.
You can create several presets and switch between them to apply their values to the CAO template by simply clicking on them. Once they are clicked, you can also override the preset by changing the tuning data of inner audio objects or the preset name.
Only after Compound Audio Object is saved, the Preset control feature will be available for configuration.
If you do not enter a preset name, it will take the default name of the New Preset.
Set presets are available for application, only on exiting Compound Audio Object editor view.
Reset Presets
To Reset Presets
- On the Preset section, select the slots, and then click on the settings icon.
- Click on Reset Selected to reset the selected preset slots.
If you want to reset all presets of the respective native panel, click Reset All.
Apply Presets on CAO Instances
If presets are available in CAO templates, you can apply these presets to CAO instances in the main signal flow.
- On the Signal Flow Designer window, right-click on compound audio object instance, go to Apply preset tuning data, and then select the required presets displayed in sub-menu.
- Click Ok to apply the tuning data of a preset to all inner audio-objects of the selected compound audio object. After applying the tuning data a successful message will be displayed.
Apply preset tuning data option will be available only when signal-flow is in saved state.
Presets will be exported/imported along with a Compound audio object template.
