Rate Control
The Rate Control audio object controls the rate at which control signals can pass through the object. This is implemented by blocking the controls for a duration that is specified as a tuning parameter.
Rate control Properties
Below table describes the audio object properties and functionalities.
Properties Description
Number of controls Enter the number of control inputs.
The number of control outputs is always 2. The index of the pin (which receives the first control signal) is sent out on the left output pin first and then the control signal itself is sent on the right output pin.
  • Range: 1 to 255
  • Data type: xFloat32
  • Default: 1
Display Name Display name of the Rate control audio object in signal flow design. It can be changed based on the intended usage of the object.
Mode
There are currently no modes available for the Rate control audio object.
Additional parameters
There are no additional parameters available for the Rate control audio object.
Tuning Parameters
There are blocking times associated with each control input pin which could be changed as a tuning parameter.
Parameter Description Data Type Range Default Unit
BlockingTime Time for which any new control signal is blocked xFloat32 0 – 60 0 seconds
Control Interface
The object supports configurable number of control inputs ranging from 1 to 255. The default number of control input is 1. The objects supports two control outputs.
Native Panel
Rate control audio object does not support a native panel.
