Retrieve Parameter Sets
The Retrieve function updates the parameter set values, with respect to changes made in the state variable.
Retrieve will change the values in the state variable and transfer the changes to the parameter set
- Open the native panel and move the slider to change the values.
- On the Parameter set group workspace and click Retrieve.
- Click Yes to confirm to complete the operation.
You will see the parameter set value will be updated with respect to the state variable, which are mapped in to the respective native panel.
Verify Parameter Sets
This functionality is designed to compare the presets loaded on a device with those available in the GTT in order to ensure their accuracy.
This feature is available only in online mode. i.e. only when the device is connected.
To verify preset values, select a preset and then click the ‘Verify’ button. A read command is sent to the device for each state variable within the preset. Once the value has been read, it will be compared with the corresponding value in the preset. If all values match, the verification process is considered successful.
However, if any values do not match, an error message will be displayed, and an error report will be generated.
Sample error report is as attached here Set 1[2].
Verify functionality is available at the Master Preset Controller level as well. You can verify all the presets under a slot in online mode.
