Set password for Compound Audio Object
Adding a password to a compound audio object (CAO) can ensure its security. During the creation or modification of a CAO, it is possible to add a password, although this step is not mandatory.
It is important to remember the password in order to access and view the signal flow of the Compound Audio Object (CAO).
To enhance the security of the CAO, it is advisable to periodically change the password at specific intervals. This measure can help prevent unauthorized access and ensure the continued protection of the CAO. The signal flow should be saved after entering or updating the password.
Click on the edit CAO option to view the signal flow. If the CAO contains a password, an authentication dialog box will be displayed. Enter the valid password to view the CAO Signal flow.
