Fader Balance Panel
Basically, this audio object allows to identify the “sweet spot” of the sound by moving in the x and y directions. Using this method, you can optimize the sound loudness on the left or back of the cabin.
Used to map the channels to Balance Speaker group and Fader speaker group.
A screenshot of a computer Description automatically generated
  • Morphing time: The range is from 0 s (no morphing) to 0.1 s.
    Morphing time follows time constant and the morphing time is denoted as M. Following is the percentage of change achieved:
    – After M: 63%
    – After 2M: 86%
    – After 3M: 95%
    – After 4M: 98%
    – After 5M: 99%
    Hence the morphing time can be configured accordingly.
The morphing time (through V release) is actually a time constant.  Therefore if you want your morph 99+% complete in 100ms you should specify 20ms, not 100.  One time constant will morph 63% of the way there.
  • Channel assignment: Assigns a particular audio channel to one or none of the speaker types in each group.
    • Balance Speaker Types: CENTER, LEFT & RIGHT
    • Fader Speaker Types: CENTER, SIDE, BASS, FRONT & REAR
Fader tab
Used to control the gain level of fader in the range -128  to 0 dB.
  • Front
  • Center
  • Side
  • Rear
  • Bass
Balance tab
Used to control the gain level of balance in range -128 dB to 0 dB.
  • Center
  • Left
  • Right
