Level Monitor Panel
Level monitor custom native panel can be used to visualize measurements and to tune measurement parameters, like types of level values. Panel shows as many channels as it is specified in SFD.
Level Monitor object has 2 working mode.
Level Monitor: Level Monitor mode is used by engineers to measure level of volume in audio pipeline.
Clip Meter: Clip Meter mode is used to check if the level is causing clipping.
State tab is used to show the level values or clipping indicators. This tab is read only.
Tune and custom tabs are used to adjust measurement parameters.
